November 14, 2016, 11:10 |
Connecting Boundaries
Rep Power: 10 |
I'm working with a multiphase flow and I encountered a problem. Let's say a flow from Inlet A flows through a tunnel and exists at Outlet B. Now there is a pipe (C) connected at the top middle of the tunnel with a flow into the tunnel. The flow of C should be the same as at the outlet B. So B and C are kind of like connected. So my question is, is there a boundary condition for C to connect the velocity (and other parameters like alpha for multiphase flow) to the Inlet-Boundary B? Thanks for your help! Last edited by dani2702; November 14, 2016 at 15:08. |
November 14, 2016, 12:57 |
Saideep
Rep Power: 12 |
Hi, it would have been better if you attached a picture of your domain.
From my understanding, I dont see why would you need a boundary at the intersection of B and C. There would be only one outlet and that would be for C pipe. |
November 14, 2016, 15:07 |
Rep Power: 10 |
So here is a picture of it. Hope this will clear things up!
November 14, 2016, 16:52 |
Philippose Rajan
Rep Power: 25 |
A Good Day to you. In my opinion, this would be a good case to use the groovyBC boundary condition which comes as part of the swak4Foam library. You can force the inlet flow at C to be equal to the outlet flow at B. Search for groovyBC coupling on the forum and on Google. Regards, Philippose |
boundary condition, connection, coupling, multiphase |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 11:04 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
Periodic Boundaries in GAMBIT!! | swetha | FLUENT | 1 | November 26, 2006 22:02 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 13:11 |
