How to define a circular truncated cone region?
Old   November 13, 2016, 10:32
Default How to define a circular truncated cone region?
wenju liu
Aaron liu is on a distinguished road
I want to define a circular truncated cone in setFieldsDict, and i think i can do it by defining a hex, but i want to know whether there are an easier method to do it?
regards, and thanks.
arron liu
Aaron liu is offline   Reply With Quote
Old   November 14, 2016, 00:21
Default My progress
wenju liu
I'm very sad about the method by defining a hex, because i find all hex were defined while i just want to define one hex. So if there are some other ways to do it, please tell my. And i will really appreciate it.
Thanks!
Arron liu.
Old   November 19, 2016, 12:28
wenju liu
I have solved this question and i want to share with you. First, you should construct your model. Then, saving as *.stl. finally, using the surfacetocell. This question will be solved.
Thank you.
Arron liu
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 05:30
Velocity Profile for flow over circular cone rameshbhoraniya FLUENT 3 March 30, 2016 03:11
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 08:32
How to define the Initial Region of Fluid in VOF Sajjad Hussain CFX 2 March 6, 2007 06:08
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
