Problem with surface feature extract
Old   November 9, 2016, 14:56
Default Problem with surface feature extract
Sandyy
sandyy235 is on a distinguished road
Am running this command for surfacefeatureextract of ahmed body
time (surfaceFeatureExtract -includedAngle 179 constant/triSurface/ahmed.stl constant/triSurface/ahmed.eMesh > Run_logs/surface_feature_extract.log) 2>> Run_logs/surface_feature_extract.log
but the log file that is getting generated is showing error
Usage: surfaceFeatureExtract [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-dict <file> read control dictionary from specified location
-noFunctionObjects
do not execute functionObjects
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
extract and write surface features to file
Using: OpenFOAM-3.0.x (see www.OpenFOAM.org)
Build: 3.0.x-a2e25d5b6e39
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 3
Invalid option: -includedAngle
FOAM exiting
real 0m0.152s
user 0m0.148s
sys 0m0.004s
Can anyone please suggest what is the wrong parameter am giving while typing this command
sandyy235 is offline   Reply With Quote
Old   November 10, 2016, 12:07
cutter is on a distinguished road
obviously the option is not within the list (you can check with surfaceFeatureExtract -help). I think the behavior changed in one of the previous versions, you need to provide a surfaceFeatureExtractDict now. Please have a look at https://github.com/OpenFOAM/OpenFOAM...ureExtractDict and the tutorial cases (for example https://github.com/OpenFOAM/OpenFOAM...ureExtractDict) for available options within that dictionary file (you probably don't need to use all of them).
Good luck!
Cutter
cutter is offline   Reply With Quote
Old   November 11, 2016, 05:37
Sandyy
Thanks for the help
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
