twoPhaseEulerFoam
Old   November 5, 2016, 11:44
Default twoPhaseEulerFoam
Wuben
lixinhai is on a distinguished road
I've just met some troubles in using twophaseeulerfoam. It was crash after a few iterations. I want to know why the value of the Min(alpha.air) become negative?
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading g
Reading hRef
Creating twoPhaseSystem
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
Calculating face flux field phi.air
Selecting diameterModel for phase air: isothermal
Selecting turbulence model type LES
Selecting LES turbulence model Smagorinsky
Selecting LES delta type cubeRootVol
SmagorinskyCoeffs
Ce 1.048;
Ck 0.094;
type heRhoThermo;
transport const;
thermo hConst;
equationOfState perfectFluid;
specie specie;
Calculating face flux field phi.water
Selecting diameterModel for phase water: constant
Selecting LES turbulence model NicenoKEqn
NicenoKEqnCoeffs
Ce 1.048;
Ck 0.094;
alphaInversion 0.3;
Cp 0.094;
Cmub 0.6;
Selecting default blending method: linear
Selecting aspectRatioModel for (air in water): constant
Selecting aspectRatioModel for (water in air): constant
Selecting dragModel for (air and water): segregated
Selecting swarmCorrection for (air and water): none
Selecting dragModel for (air in water): SchillerNaumann
Selecting swarmCorrection for (air in water): none
Selecting dragModel for (water in air): SchillerNaumann
Selecting swarmCorrection for (water in air): none
Selecting virtualMassModel for (air in water): constantCoefficient
Selecting virtualMassModel for (water in air): constantCoefficient
Selecting heatTransferModel for (air in water): RanzMarshall
Selecting heatTransferModel for (water in air): RanzMarshall
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 7.7598e-09 max: 5.87416
Max Ur Courant Number = 5.87416
Calculating field DDtU1 and DDtU2
Starting time loop
fieldAverage fieldAverage1:
Starting averaging at time 0
Time = 0.0001
PIMPLE: iteration 1
MULES: Solving for alpha.air
alpha.air volume fraction = 1.55196e-08 Min(alpha.air) = 0 Max(alpha.air) = 11.7483
Constructing momentum equations
smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 9.96649e-09, No Iterations 52
smoothSolver: Solving for e.water, Initial residual = 0.000156734, Final residual = 0.000104913, No Iterations 1000
min T.air 288.637
min T.water 300
GAMG: Solving for p_rgh, Initial residual = 0.961306, Final residual = 9.18955e-09, No Iterations 64
PIMPLE: iteration 2
alpha.air volume fraction = 1.145e-07 Min(alpha.air) = 0 Max(alpha.air) = 52.5699
smoothSolver: Solving for e.air, Initial residual = 0.483324, Final residual = 9.39689e-09, No Iterations 190
smoothSolver: Solving for e.water, Initial residual = 0.999981, Final residual = 9.55165e-09, No Iterations 25
min T.air -636.587
min T.water 299.973
GAMG: Solving for p_rgh, Initial residual = 0.800368, Final residual = 9.36696e-09, No Iterations 59
PIMPLE: iteration 3
alpha.air volume fraction = 0.000124845 Min(alpha.air) = -350247 Max(alpha.air) = 337950
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4 pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foamw(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:?
#6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foamw<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
#7 Foam::dragModels::SchillerNaumann::CdRe() const at ??:?
#8 Foam::dragModel::Ki() const at ??:?
#9 Foam::dragModel::K() const at ??:?
#10 Foam::BlendedInterfacialModel<Foam::dragModel>::K( ) const at ??:?
#11 Foam::twoPhaseSystem::Kd() const at ??:?
#12 ? at ??:?
#13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14 ? at ??:?
lixinhai is offline   Reply With Quote
Old   November 5, 2016, 19:26
Wouter van der Meer
wouter is on a distinguished road
hello lixinhai,
try a smaller timestep your courant number should be less than 1.
To be able to help you more you need to read the first few posts on how to ask questions. You need to give more information.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   November 5, 2016, 20:46
Wuben
Thank you for reply.
I've set the courant number less than 0.5 and the timeStep is modifiable,but the case is still crash after a few iterations.
openfoam
twoPhaseEulerFoam: sudden crash hcen OpenFOAM Running, Solving & CFD 18 September 29, 2020 04:04
twoPhaseEulerFoam and complex geometry bsoubelet OpenFOAM Running, Solving & CFD 7 July 2, 2015 11:50
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? ThomasV OpenFOAM 0 November 11, 2013 09:10
Something wrong in UEqns.H within twoPhaseEulerFoam cheng1988sjtu OpenFOAM 2 June 24, 2011 11:48
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 17:24
