cavity tutorials
Old   November 1, 2016, 11:22
Default cavity tutorials
Francesco Saverio Ciani
ciaci88 is on a distinguished road
I am trying to run my first tutorial about the cavities, but I have to many doubts and morever the code does not work. This openfoam version is running in windows 10.
This is my code:
C:\Program Files (x86)\ESI\OpenFOAM\1606>"C:\Program Files (x86)\ESI\OpenFOAM\1606\Windows\Scripts\of_start_c ontainer.exe" -Arguments "C:\Program Files\Docker Toolbox\;C:\Program Files\Git\bin"
Starting "default"...
Machine "default" is already running.
of_plus_1606
[ofuser@default ~]$ mkdir -p $FOAM_RUN
[ofuser@default ~]$ cp -r $FOAM_TUTORIALS $FOAM_RUN
[ofuser@default ~]$ cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity/cavity
[ofuser@default cavity]$ ls
0 constant system
[ofuser@default cavity]$ cd constant
[ofuser@default constant]$ ls
transportProperties
[ofuser@default constant]$ cd polyMesh
bash: cd: polyMesh: No such file or directory
Now my questions are:
1) Where can I find this folders (tutorials/incompressible/icoFoam/cavity/cavity)on my computer?
2) Where can I find the polymesh file?
3)Why Openfoam cannot find polymesh file?
Thank you in advance
ciaci88 is offline   Reply With Quote
Old   November 2, 2016, 04:48
Brian Willis
Dipsomaniac is on a distinguished road
1) It should be in your default user directory.
2) Run the blockMesh application to generate the polyMesh directory, including the files relating to the generated mesh.
3)it doesn't exist yet till you run your blockMesh application.
Dipsomaniac is offline   Reply With Quote
Old   November 2, 2016, 09:45
Hi Dipsomaniac, thank you very much for your help
1) Can you specify the path of the default user directory?
2) How can I run the blockMesh application to generate the polyMesh directory? This step is missing in the tutorial
Old   November 2, 2016, 16:20
This is the only folder that I have found related to Openfoam. I cannot find any folder with the tutorials in this folders. Should I search in an other folder?
Which command should I type to run polyMesh?
Old   November 13, 2016, 15:46
khedar
khedar is on a distinguished road
You have to run 'blockMesh' command from the 'cavity' directory. This will create a directory called 'ployMesh' in 'constant' where all the mesh info will be stored. After doing this you should be able to see this directory.
khedar is offline   Reply With Quote
[ICEM] Meshing a cavity within an aerofoil Alwaysabeginner ANSYS Meshing & Geometry 5 August 13, 2022 11:59
Flow over a cavity inconsistent Sparow89 FLUENT 0 June 20, 2016 13:02
cavity in flat plate and drag prediction Far FLUENT 0 May 19, 2010 15:47
[blockMesh] basic blockMesh : manipulate the lid-driven cavity flow tutorials Lexa OpenFOAM Meshing & Mesh Conversion 2 November 12, 2009 22:15
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
