Running the Openfoam tutorials
Old   November 1, 2016, 05:24
Default Running the Openfoam tutorials
Bala
balav94 is on a distinguished road
Hi everyone!
I am new to Openfoam and trying to run some tutorials. One such tutorial is this-
https://github.com/OpenFOAM/OpenFOAM...nWithObstacles
I am not able to understand the README file provided, as I am not able to figure out the functions necessary to run the case.
PDR test case Step to introduce the PDR fields: 1) Create zero-size patches for wall or/and coupled baffles in the boundary file. 2) Specify the boundary contitions for these patches in the fields. 3) Create the new PDR mesh using the PDRMesh utility.
It would be great if someone can help me run this tutorial.
Thanks!
balav94 is offline   Reply With Quote
Old   November 9, 2016, 11:42
khedar
khedar is on a distinguished road
Try reading the README along with the Allrun script which might help. Normally running allrun script is all you need to run a case and hence you can figure it out what steps you need to follow for running a case
runApplication blockMesh
runApplication changeDictionary
runApplication topoSet
runApplication PDRMesh -overwrite
1. blockmesh creates the mesh (Step 1 of readme probably?)
2. changeDictionary specifies the boundary conditions (Step 2)
3. PDRMesh with over write option will create PDR mesh and overwrite the existing mesh(Step 3)
khedar is offline   Reply With Quote
Old   November 9, 2016, 12:30
Bala
Hi Khedar!
I am currently having issues with my system. I will try this and get back to you.
However, I did read the Allrun script. I was facing some error in the changeDictionary step. I will post the error once I try it out, in 2-3 days
Thanks!
Old   November 14, 2016, 05:29
Bala
Hi Khedar!
When I run the 'changeDictionary' command, I get the following error. Can you help me out?
balavignesh@bumblebee:~/OpenFOAM/balavignesh-4.1/run/flamePropagationWithObstacles$ changeDictionary
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1-1e03d68d4f4e
Exec : changeDictionary
Date : Nov 14 2016
Time : 14:52:26
Host : "bumblebee"
PID : 10607
Case : /home/balavignesh/OpenFOAM/balavignesh-4.1/run/flamePropagationWithObstacles
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Read dictionary changeDictionaryDict with replacements for dictionaries 1(dictionaryReplacement)
Reading polyMesh/boundary file to extract patch names
Loaded dictionary boundary with entries
6
outer
ground
blockedFaces
baffleWall
baffleCyclic_half0
baffleCyclic_half1
Extracted patch groups:
group cyclic with patches
2
baffleCyclic_half0
baffleCyclic_half1
group wall with patches
3
ground
blockedFaces
baffleWall
Replacing entries in dictionary dictionaryReplacement
Loading dictionary dictionaryReplacement
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/balavignesh/OpenFOAM/balavignesh-4.1/run/flamePropagationWithObstacles/0/dictionaryReplacement at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 72.
FOAM exiting
Old   November 14, 2016, 05:55
khedar
It seems there is no dictionaryReplacement file at the specified Location..
Edited:After trying the tutorial myself.
I tried running the case with Allrun script and it ran fine, without any problem.
Then i tried all functions individually and again it worked fine. Don't forget to rename 0.org to 0 before running anything.
cp -r 0.orig 0
blockMesh
changeDictionary
topoSet
PDRMesh -overwrite
PDRFoam
Last edited by khedar; November 14, 2016 at 06:54. Reason: More detailed explanation
Old   November 15, 2016, 03:53
Bala
Hey Khedar!
I tried it again. This time, I manually replaced the boundary conditions & associated values instead of using 'changeDictionary'. It worked. However, I got the same error when I ran the 'changeDictionary' function.
But, once I load the solution into ParaView, I am not able to see which is the obstacle past which the flame is propagating and what the domain is, in this problem. Were you able to? If yes, can you explain me?
Thanks anyways!
Old   November 23, 2016, 03:39
Bala
Hi Khedar!
I successfully managed to setup my case using XiFoam. However, after a few timesteps, I am getting the janaf (temperature out of bounds) warning. Eventually, after some timesteps, the simulation stops.
I searched through the posts and found some threads. But, I am not able to understand as to how I can resolve this error.
Can you (or someone else) help in this regard?
Thanks!
Old   November 24, 2016, 05:46
khedar
Reply to post 6: did you copy 0.org Folder to 0 Folder before running the changeDictionary ?
Reply to post 7: normally out of bounds error for any field Variable is either due to Bad Mesh or improper boundary conditions..I would suggest you to do a checkMesh for your Mesh and recheck your boundary conditions.. Below is a link to a seemingly good Tutorial on XiFoam.I have no experience with it..
Good luck.
http://www.tfd.chalmers.se/~hani/kur...port.pdf<br />
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Looking for more details on Openfoam tutorials Balux OpenFOAM 0 May 18, 2014 11:13
Running in parallel with a machine that doesn't have OpenFOAM aujamal20 OpenFOAM Running, Solving & CFD 1 September 14, 2013 11:08
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com Markus Schmidberger OpenFOAM Announcements from Other Sources 0 July 26, 2011 09:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
