How to use the data generated by function objects at run-time? |
October 31, 2016, 12:44 |
Jun Zhang
Rep Power: 12 |
Hi All
I have used function objects (put it in /system/controdict) to extract iso-surface for each output time step. Now I want to develop some code using the iso-surface to calculate some more quantities at run-time. And these quantities are then used as input parameters for some equations. How can I get access to the data generated by function objects at run-time? Many thanks! |
November 1, 2016, 06:55 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 23, 2015 00:05 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
