UHGAR
Rep Power: 9 ![]() |
Dear Foamers,
Can someone let me know, how to calculate Integral, Taylor and Kolmogrov length scales from oneEqEddy and Smagorinsky model? oneqEddy is outputting 'k' but not epsilon and Smagorinsky is outputting neither. 1) How can be able to get epsilon ? what relations I need to use between 'k' and 'epsilon' to get three length scales? 2) I heard, LES only models sub grid scales. Is it possible to get Integral length scales from LES simulation? How can I be able to do this? Thanks, UHGAR |
#2 | |
Timofey Mukha
Rep Power: 14 ![]() |
1) As you correctly point out the k for LES will only correspond to the energy of the subgrid scales, which you model. To get the the full k you should also add the resolved part of k, which you can get through the diagonal components of the Re-stresses (UPrime2Mean in OpenFOAM). Dissipation is harder, since it involves derivatives. The relations connecting k and eps to the Taylor microscale are given on page 2000 of Pope's "Turbulent flows". Re_L = k^2/(eps*nu) lambda = sqrt(10)*Re_L^(-1/2), where lambda is the microscale. 2) yes, it is possible, by computing two-point correlations of velocity in space, see the last appendix in https://www.it.uu.se/research/public...4/2015-014.pdf But there is no "neat" way to do this, I had to simply use probes to save the time-series of the velocity field at many points along the desired direction and compute the correlations using these huge datasets. I realize my answer is perhaps to condensed to be very helpful, but hopefully better than nothing. Best, Timofey |
length scales, les jet |
LES of Turbulent Jet | knuckles | OpenFOAM Running, Solving & CFD | 1 | March 31, 2016 19:33 |
Best LES solvers for confined or unconfined turbulent swirl jet flow | engma3 | OpenFOAM Running, Solving & CFD | 0 | December 25, 2011 02:47 |
LES on a scaled geomentry (Mesh and Large scales) | comb | Main CFD Forum | 0 | February 8, 2011 06:21 |
characteristic time and space scales while formulating appropriate LES model | yinjunlian | FLUENT | 0 | April 28, 2009 04:03 |
length scales at inlet for internal flows | Anne-Marie Giroux | Main CFD Forum | 3 | July 5, 1999 21:28 |
