Extract Velocity Profile
Old   October 25, 2016, 19:12
Arrow Extract Velocity Profile
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
i want to extract the velocity profile at the outlet of my channel for using it as initial condition in another simulation.
My question is: how can i extract it?
The only way i found till now is the "readFields" tool but i don't know how to adapt it for the profile over a boundary. Can someone explain me how to modify it?
readFields1
    type        readFields;
    functionObjectLibs ("libfieldFunctionObjects.so");
    fields      (U p);
If there was another way to do what i need it would be fantastic in the same manner.
Thank for help and your time.
Roberto
FlyBob91 is offline   Reply With Quote
Old   October 26, 2016, 05:45
danielbanos10's Avatar
danielbanos10 is on a distinguished road
There is a tool, that seems that is what you are searching for, MapFields
https://openfoamwiki.net/index.php/MapFields
danielbanos10 is offline   Reply With Quote
Old   October 26, 2016, 13:13
Timofey Mukha
tiam is on a distinguished road
Originally Posted by FlyBob91 View Post
Hello to all,
readFields1
    type        readFields;
    fields      (U p);
Roberto
Hi!
What do you mean by "profile"? If it is a surface of a line -- use the sample utility.
tiam is offline   Reply With Quote
Old   October 27, 2016, 10:05
FlyBob91's Avatar
Originally Posted by tiam View Post
Hi!
hello tiam, thank you for your reply.
For profile i mean the value of the velocity field for every cells at the output.
Regards,
Roberto
Old   October 27, 2016, 10:25
Timofey Mukha
Regards,
Roberto
Hi Roberto,
If you can live with using face-values at the outlet instead, use the sample utility for surface-sampling.
If you really need the cell values, you might have to code your self.
It is possible to grab the cell-center value associated with the patch-face, so it be doable. Explor the fvPatchField classes and ralated things for that.
Best,
Timofey
Old   October 28, 2016, 00:18
Ping Chang
chpjz0391 is on a distinguished road
Regards,
Roberto
Hi Roberto,
I think you can achieve this by using ParaView. Using the "select cells on" function, then you can select the cells on the outlet. Then you can read the data on the cells which you chose and output the data on the cells.
Regards,
Ping
chpjz0391 is offline   Reply With Quote
Old   December 15, 2018, 12:18
Default Code snippet to write outlet velocity as an fixedValue boundary condition
victorious_BIG is on a distinguished road
This code snippet will extract the outlet velocity of a case on the patch named "outlet" and then write the output formatted as a fixedValue BC for a velocity inlet. Just copy and past the buffer output into your 0/U file.
Paste the following into the bottom of your solver and compile (wmake):
const label& patchID = mesh.boundaryMesh().findPatchID("outlet");
const fvPatch& outPatch = mesh.boundary()[patchID];
const fvPatchField<vector>& outU =
outPatch.lookupPatchField<volVectorField, vector>("U");
const vectorField outUvalues = outU.patchInternalField();
Info << " type fixedValue;" << endl;
Info << " value nonuniform List<vector>" << endl;
Info << " " << outUvalues.size() << endl;
Info << " (" << endl;
forAll(outUvalues,vecI)
Info << " (" << outUvalues[vecI][0] << " 0 0)" << endl;
Info << " );" << endl;
victorious_BIG is offline   Reply With Quote
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
3d velocity profile at velocity inlet swethaprakash FLUENT 3 September 1, 2015 03:10
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 16:31
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 13:14
