October 23, 2016, 13:48 |
rigidBodyDynamics library using restraints
Navdeep kumar
Hii
I am a new user in openFoam. I have been trying to use rigidbodydynamics library(introduced in new versions of openfoam) to simulate floating object on which a linear damper or linear spring restraint has been applied. This spring will have one end on the object and the other end attached to stationary walls. Floating object tutorial exists but it does not have any restraints. It can be seen in the dynamicmesh dict. dynamicmeshdict.sixdof is for the older sixdofrigidbodymotion library. Please don't use that dictionary. Also if i want to couple two bodies interconnected by spring or damper. Is there any way to do it. This case is more difficult as the two bodies are floating on water so we don't have a fixed anchor position for the spring or damper. The dynamicmeshdict for linear spring restraint for a floating object ahs been edited to looks like this: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object motionProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("librigidBodyMeshMotion.so"); solver rigidBodyMotion; rigidBodyMotionCoeffs { report on; solver { type Newmark; } accelerationRelaxation 0.7; bodies { floatingObject { type cuboid; parent root; bodyID floating; // Cuboid dimensions Lx 0.3; Ly 0.2; Lz 0.5; // Density of the cuboid rho 500; // Cuboid mass mass #calc "$rho*$Lx*$Ly*$Lz"; L ($Lx $Ly $Lz); centreOfMass (0 0 0.25); transform (1 0 0 0 1 0 0 0 1) (0.5 0.45 0.1); joint { type composite; joints ( { type Py; } { type Ry; } ); } restraints //restraint { horizontalspring { type linearSpring; bodyID floating; anchor (0.5 0 0.35); refAttachmentPt (0.5 0.35 0.35); //reference attachment point stiffness 1000000; damping 0; restLength 0.1; } } patches (floatingObject); innerDistance 0.05; outerDistance 0.35; } } } // ************************************************** *********************** // This does not seem to work as restraints are not being read when this case is executed. It works as if not restraints exist. |
dynamic mesh, floating body, restraints, rigid body motion |
[Other] Multi species mass transport library [update] | novyno | OpenFOAM Community Contributions | 111 | November 10, 2021 00:37 |
ERROR: unable to find library | HJH | CFX | 6 | February 26, 2019 07:52 |
Compiled library vs. inInclude Files, DSMC solver crashes after run | GPesch | OpenFOAM Programming & Development | 8 | April 18, 2013 08:17 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 16:49 |
