October 12, 2016, 08:11 |
Field average
Alessandro
Rep Power: 10 |
Hello to everyone,
Today I am going to write you because of problems regarding to field averages. I run my simulation in turbulent regime without doing average field until a certain time ( the time where it can be assumed that convergence is reached). After that time the solver starts to do the average of the variables but does not save anymore the local variables (p. U etc). This not only would be a problem during the post processing but It denies to restart the simulation from a previous time step as pressure field is needed. Does someone know which setting should I change? Regards Pappo |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
OpenFOAM floating point Error | upuli | OpenFOAM Programming & Development | 5 | June 20, 2016 03:19 |
Field Average on a plane | li. | OpenFOAM Post-Processing | 0 | September 22, 2015 16:29 |
Parallel run Slows with Field average | owayz | OpenFOAM Running, Solving & CFD | 0 | October 12, 2012 23:22 |
