index in traansonicMRFDyMFoam
Old   October 4, 2016, 11:17
Default index in traansonicMRFDyMFoam
James B. Wullf
jbwulf is on a distinguished road
I am using OpenFOAM 1.6–extend with Ubuntu 14.04 . My case is a single centrifugal compressor blade and I am using the transonicMRFDyMFoam solver. blockMesh has given a reasonable looking grid with an eliptical blade leading edge made with spline and an arc trailing edge. My case is identical with the Axial_Rotor_MRF tutorial from DensityBasedTurbo except for the blockMeshDict file. The case does not run and gives the error,
--> FOAM FATAL ERROR:
index -1 out of range 0 ... 6
From function UList<T>::checkIndex(const label)
in file /home/jbwulf/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/UListI.H at line 119.
FOAM aborting
Aborted (core dumped)
What is index? Where does it come from and how do I fix the error?
Jim
jbwulf is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
