How to import geometry from AUTOCAD to OPENFOAM |
September 29, 2016, 03:34 |
MASc Student
Rep Power: 10 |
Hi there,
Very new to OpenFoam.. I want to import a model from autocad to make it easier to create the geometry/mesh. How can I import this file into the simulation? I believe i have to save as .stl file. Where/how do I put this into the source file? How can i easily assign boundary conditions to the faces? I.e. if there were thousands of faces, without having to go through the individual faces, point numbers, right hand rule etc... Please help!!!! I want to import a model of a beach section with bathymetry, so almost everything will be zerogradient condition, but there will be MANY faces |
September 29, 2016, 07:44 |
Rep Power: 21 |
You need to create a mesh your solver can use. You should look into the tutorials on how to use snappyHexMesh or use a commercial meshing software.
mesh import geometry stl |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
Geometry in OpenFoam | Mirage12 | OpenFOAM Pre-Processing | 3 | May 24, 2013 01:11 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Import autocad into Design modeller | lcea | CFX | 0 | November 30, 2010 05:13 |
