hi guys. I have some problems making heatTransfer |
September 7, 2016, 22:07 |
bye bye my blue
Rep Power: 9 |
I wanna make the HeatTrasnfer solution between 2 fluids or solids
(it doesn't matter 1 solid and 1 fluid) On a simple hexahedron which inlet and outlet have different heat conductivity. Finally, When inlet and outlet have temperature ( same or different), I wanna observe the flow by the different heat conductivity. i don't know what should I do -_-. plz help me. i'm new thx |
September 8, 2016, 09:47 |
Tobias Holzmann
Rep Power: 52 |
Hey,
out of the box I do not get the point what you want to do. You should investigate a bit more time in writing your question in order that other people know what you are want to do. For conjugated heat transfer you should use the chtMulti solver. If you only want to simulate a simple case with two different settings you can use other solvers. I don't get the point with the two different conductivities at the inlet. If you have more than one region in your simulation, you need to use cht (of course there are other ways, like implementing it yourself etc.)...
Keep foaming, Tobias Holzmann |
September 8, 2016, 21:51 |
modi
bye bye my blue
Rep Power: 9 |
l--------------------------------- l
l----------------------------------l (left side is inlet, right side is outlet. on rectangular-parallelepiped) inlet and outlet have different conductivity. The temperature doesn't matter. When the iteration increase, I wanna observe heat transfer. <- it's main i have bad english skill.. sorry ToT Last edited by bye bye my blue; September 8, 2016 at 23:25. Reason: fixing the message |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 06:26 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
[blockMesh] Problems of mutiple regions | fw407 | OpenFOAM Meshing & Mesh Conversion | 2 | February 8, 2008 08:54 |
HELPInstallation on RedHat90 | booosix | OpenFOAM Installation | 8 | July 17, 2007 07:40 |
