about $internalFields in boundary condition
Old   September 4, 2016, 19:31
Default about $internalFields in boundary condition
openfoammaofnepo is on a distinguished road
Dear All,
What does it mean by $internalFields? Such as in the following example:
        type            totalPressure;
        p0              $internalField;
        U               U;
        phi             phi;
        rho             none;
        psi             none;
        gamma           1;
        value           $internalField;
When I used in my simulations with OF2.1.1 fireFOAM solver, I meet the following problem as:
--> FOAM FATAL IO ERROR:
compound has already been transfered from token
on line 20 the empty compound of type List<scalar>
file: /home/user/case/0.0039075/p_rgh::boundaryField::OUTFLOW:0 at line 20.
From function token::transferCompoundToken(const Istream& is)
in file lnInclude/token.C at line 99.
FOAM aborting
I check the line 20 in the file p_rgh:
it is as follows:
internalField nonuniform List<scalar> // This is line 20
90111
I think the data for the internalField are fine. But I am not sure when I use "$interalFields" as the tutorials, the above mentioned error information always appears. I do not know what is the real reason for this. Anybody has the same problems?
Thank you so much.
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   September 5, 2016, 07:35
Roman
Roman1 is on a distinguished road
Hello. Everything works OK if BC is taken from the C++ guide (http://cpp.openfoam.org/v4/a02729.html). As I know, the exact value of the pressure must be pointed.
Roman1 is offline   Reply With Quote
Old   September 5, 2016, 13:21
Thank you for pointing out the link. So do you mean for value in this BC type, is it not good to use $internalField here?
Old   September 6, 2016, 02:47
Roman
Yes, since it does not work.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
