trimmed mesh generated by Star-ccm diverged suddenly running in OpenFOAM |
August 16, 2016, 04:31 |
Rep Power: 10 |
Hello, all
I encounter a problem which puzzles me a lot. I generated the trimmed mesh in star-ccm and then converted it to openfoam. I checked the quality of mesh using checkMesh in openfoam and everything seems fine. However, the case diverged suddenly during a few time steps, when it ran about 13.5 round trips in the computational domain. Before that, the CFL number is about 1.2~1.3 and the results is promising. The geometry is a simple cube. Then, I enlarged the first refinement box trying to include the whole recirculation region behind the cube and keep everything else exactly the same. The difference between the mesh can be seen in the attached pictures. In the common sense, the mesh quality should be improved after the enlargement of refinement box. Unfortunately, the case diverged even more quickly... less than a round trip Does anyone have any ideas about what's going on? Thank you very much. Best wishes |
diverged, openfoam, trimmed mesh |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Problem mesh importing to STAR CCM | mohammad | Mesh Generation & Pre-Processing | 0 | January 19, 2015 22:45 |
Running Openfoam after converting the mesh file | archeoptyrx | OpenFOAM Running, Solving & CFD | 1 | May 4, 2013 09:20 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
