Unable to run the case parallel using foam-extend in the cluster |
July 27, 2016, 23:49 |
Farah Aqilah
I tried to run my case parallel using foam-extend in the cluster (access by Putty or openSSH) utilizing 16 cores (using 'mpirun' and 'runParallel' code). In the meantime, I run the same case of foam-extend parallel in my desktop computer which have only 8 cores. However, the problem is that it takes a much more time to complete one revolution from using the cluster compared to the desktop computer. providing that I only use 8 cores. Is this possible? It seems like the cluster are unable to run the case parallel but in series. Can someone help me recognized the problem. Sorry, I'm new in OpenFOAM and foam-extend. I did not know much about it. |
cluster, foam-extend-3.2 |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 6 | June 24, 2024 03:17 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
