July 23, 2016, 05:52 |
twoPhaseEulerFoam
HL
Hi,everyone. I just met some troubles by using the solver named twoPhaseEulerFoam.
I tried to run the case 'bubbleColumn' which turbulent model is LES, and it can run normally without changing anything. However,the case can't run normally when the value of 'convertToMeters' changed from 1 to 0.01 in the blockMeshDict file.blockMeshDict.c |
July 29, 2016, 08:58 |
Rep Power: 11 |
Your solver runs into negative volume fraction of air and then your temperatures drop below absolute zero and the simulation crashes. This happens when your solution doesn't converge. Check this thread for answer: http://www.cfd-online.com/Forums/ope...ultiphase.html .
July 30, 2016, 09:57 |
#3 | |
HL
openfoam, twophaseeulerfoam |
twoPhaseEulerFoam: sudden crash | hcen | OpenFOAM Running, Solving & CFD | 18 | September 29, 2020 04:04 |
residuals for velocity - twoPhaseEulerFoam | avila.vc | OpenFOAM Running, Solving & CFD | 1 | May 27, 2019 08:37 |
twoPhaseEulerFoam: Exceeding iterations, residual = NaN | Flyingcircus | OpenFOAM Running, Solving & CFD | 0 | January 2, 2016 14:18 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 09:10 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 17:24 |
