Problem
Old   July 21, 2016, 01:56
Default Problem
subhankar
SUBHANKAR is on a distinguished road
Has anyone solved the problem(2D) for flow over a pipe kept in between two infinitely large parallel plates. Inlet conditions : velocity-parabolic in one case and uniform in other case. I am getting "fatal error" when i run the blockmeshdict file.My file is:
convertToMeters 0.1;
vertices
(14.142 -14.142 0)
(14.142 14.142 0)
(-14.142 14.142 0)
(-14.142 -14.142 0)
(-28.284 -28.284 0)
(-28.284 28.284 0)
(28.284 28.284 0)
(28.284 -28.284 0)
(28.284 -100 0)
(-28.284 -100 0)
(-1000 -100 0)
(-1000 -28.284 0)
(-1000 28.284 0)
(-1000 100 0)
(-28.284 100 0)
(28.284 100 0)
(1000 100 0)
(1000 28.284 0)
(1000 -28.284 0)
(1000 -100 0)
(14.142 -14.142 1)
(14.142 14.142 1)
(-14.142 14.142 1)
(-14.142 -14.142 1)
(-28.284 -28.284 1)
(-28.284 28.284 1)
(28.284 28.284 1)
(28.284 -28.284 1)
(28.284 -100 1)
(-28.284 -100 1)
(-1000 -100 1)
(-1000 -28.284 1)
(-1000 28.284 1)
(-1000 100 1)
(-28.284 100 1)
(28.284 100 1)
(1000 100 1)
(1000 28.284 1)
(1000 -28.284 1)
(1000 -100 1)
blocks
hex(0 7 27 20 1 6 26 21)(40 80 1)simplegrading(0.5 1 1)
hex(2 1 21 22 5 6 26 25)(40 80 1)simplegrading(0.5 1 1)
hex(4 3 23 24 5 2 22 25)(40 80 1)simplegrading(0.5 1 1)
hex(3 0 20 23 4 7 27 24)(40 80 1)simplegrading(0.5 1 1)
hex(7 18 38 27 6 17 37 26)(1000 80 1)simplegrading(1 1 1)
hex(6 17 37 26 15 16 36 35)(1000 80 1)simplegrading(1 1 0.5)
hex(5 6 26 25 14 15 35 34)(40 80 1)simplegrading(1 1 0.5)
hex(12 5 25 32 13 14 34 34 33)(1000 80 1)simplegrading(1 1 0.5)
hex(11 4 24 31 12 5 25 32)(1000 80 1)simplegrading(1 1 1)
hex(10 9 29 30 11 4 24 31)(1000 80 1)simplegrading(1 1 0.5)
hex(9 8 28 29 4 7 27 24)(40 80 1)simplegrading(1 1 0.5)
hex(8 19 39 28 7 18 38 27)(1000 80 1)simplegrading(1 1 0.5)
edges
arc 0 1 (20 0 0)
arc 1 2 (0 20 0)
arc 2 3 (-20 0 0)
arc 3 0 (0 -20 0)
arc 6 7 (40 0 0)
arc 6 5 (0 40 0)
arc 5 4 (-40 0 0)
arc 4 7 (0 -40 0)
arc 20 21 (20 0 1)
arc 21 22 (0 20 1)
arc 22 23 (-20 0 1)
arc 23 20 (0 -20 1)
arc 26 27 (40 0 1)
arc 26 25 (0 40 1)
arc 25 24 (-40 0 1)
arc 24 27 (0 -40 1)
boundary
fixedWalls
type wall;
faces
(13 14 34 33)
(14 15 35 34)
(15 16 36 35)
(10 30 29 9)
(9 29 28 8)
(8 28 39 19)
(2 22 21 1)
(1 21 20 0)
(0 20 23 3)
(2 3 23 22)
inlet
type patch;
faces
(13 33 32 12)
(12 32 31 11)
(11 31 30 10)
outlet
type patch;
faces
(36 16 17 37)
(37 17 18 38)
(38 18 19 39)
mergePatchPairs
If anyone has solved this problem can you please share all the relevant files or correct mine. I am new to openfoam and it's not properly documented. Thanks in advance...
SUBHANKAR is offline   Reply With Quote
Old   July 21, 2016, 04:58
Antimony is on a distinguished road
What exactly does the error message say? It is usually the part after the "Fatal Error" that is most important and most useful in debugging.
Also, where does the error appear? When you run blockMesh or when you run something else?
And please, put the blockMeshDict stuff within a code block. Makes it a lot easier to read.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   July 22, 2016, 13:29
subhankar
Hi
Thanks for replying...The error message showing is:
FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'blocks' on line 64 and ending at line 188"
file: /home/subhankar/OpenFOAM/subhankar-3.0.1/run/tutorials/basic/potentialFoam/new/system/blockMeshDict at line 188.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
This message came aafter running the blockMesh command.
I can't understand the 'mergepatchpair' thing.
regards
Subhankar
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
