Mass fraction of species is reduced "spontaneously" in phase change solver |
July 20, 2016, 07:38 |
Michael Frank
Rep Power: 14 |
I am using the reactingMultiphaseEulerfoam to simulate evaporation of water at the interface of a bubble column. The mixture has a very small mass fraction of water (3x10^-5). I am using the Arden Buck saturation model. The temperature is 15 decgrees Celsius and the liquid is at atmospheric pressure. When I start the simulation, the the liquid water mass fraction goes to negative values almost instantly in a large number of cells. On the other hand, the mass fraction of the water vapour does not increase accordingly. Therefore, I believe that this must be some issue regarding numerical accuracy. Has anyone experienced anything similar or can shed some light as to how to overcome this problem? Thanks in advance for any help Cheers Mike |
April 28, 2022, 15:08 |
#2 | |
Vitor Monteiro
Rep Power: 6 |
I'm trying to understand your problem: are you simulating water evaporation under 15 °C (atmospheric pressure)? How could this be possible? OpenFoam8 has a interface model to simulate this. However, its used temperatures about 400 K. |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
Species Mole and Mass Fraction Macro | combustion | FLUENT | 18 | February 5, 2024 13:23 |
Accessing the species mass fraction for particles data in UDF | mac_09 | FLUENT | 17 | August 9, 2017 21:15 |
PB: Saving mass fraction of species on two points with an udf | biget.a | FLUENT | 2 | July 23, 2009 04:06 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
