Error creating multiple regions with chtmultiregionfoam |
Jagir Hussan
Rep Power: 0 ![]() |
I am trying to extend the windshieldcondensation example in openfoam 3.0+ release, to handle three regions. To start with, I created a simple problem where I want to model the condensation that may occur on a glass plate that separates two airflow zones. I created sandwich like geometry, where I have two fluid regions (SINK, FLOWZONE) separated by a solid region (GLASS). Both the fluid regions have the same parameters and fields setup (with appropriate changes to boundary patch names). However, when I run the case. I get the following error. I would be grateful if any one can help me resolve the error and get the case running. I have attached the case and the log for chtmultiregionfoam for your reference. Thanks in advance. Jagir ------------------------------------------------------------- Solving for fluid region SINK diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for h, Initial residual = 1, Final residual = 9.182139767e-06, No Iterations 71 Min/max T:260.2339105 300 GAMG: Solving for p_rgh, Initial residual = 0.7728325785, Final residual = 0.01331786674, No Iterations 4 time step continuity errors (SINK): sum local = 0, global = 0, cumulative = 0 GAMG: Solving for p_rgh, Initial residual = 0.0710420471, Final residual = 7.195808352e-07, No Iterations 32 time step continuity errors (SINK): sum local = 0, global = 0, cumulative = 0 Solving for fluid region FLOWZONE diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 --> FOAM FATAL ERROR: request for volScalarField H2O from objectRegistry FLOWZONE failed available objects of type volScalarField are 18 ( thermo:mu thermo:psi nut yWall K h rho k p_rgh dpdt gh alphat rho_0 p T omega thermo:rho thermo:alpha ) Last edited by Jagirhussan; July 19, 2016 at 02:19. |
heat transfer, multiple regions, chtMultiRegionFoam? | Ohlzen-Wendy | OpenFOAM Pre-Processing | 13 | February 8, 2022 08:17 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[CAD formats] Clean / Repair STL file with multiple regions on command line | matthiasd | OpenFOAM Meshing & Mesh Conversion | 6 | May 24, 2016 07:51 |
chtMultiRegionFoam different properties in (fluid) region(s) | volker1 | OpenFOAM Pre-Processing | 3 | February 4, 2015 07:46 |
[snappyHexMesh] Using snappyHexMesh for multiple enclosed regions | richard_vega | OpenFOAM Meshing & Mesh Conversion | 0 | November 13, 2014 15:28 |
