I got sigFpe error after applying mapFields to a subdomain
Old   July 4, 2016, 21:30
Default I got sigFpe error after applying mapFields to a subdomain
SSSSS
doctorWho is on a distinguished road
I have two domains. one is large domain and the other is a subdomain of the first one.
I ran a simulation with the large domain with RAS.
Using the RAS result, I want to map the solutions into the subdomain boundary.
After ran mapFields in the subdomain case directory, with Paraview the boundary value looks good.
However, OpenFOAM make sigFpe when I try to run a simulation with the subdomain with the mapped boundary value as follows:
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading field p
Reading field U
[23] #0 Foam::error:rintStack(Foam::Ostream&)[49] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
[49] #1 Foam::sigFpe::sigHandler(int) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
[23] #1 Foam::sigFpe::sigHandler(int) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
[49] #2 ? in "/lib64/libc.so.6"
[49] #3 Foam::surfaceInterpolation::makeWeights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so"
[23] #2 ? in "/lib64/libc.so.6"
[23] #3 Foam::surfaceInterpolation::makeWeights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so"
[49] #4 Foam::surfaceInterpolation::weights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so"
[23] #4 Foam::surfaceInterpolation::weights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so"
[49] #5 ? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so"
[23] #5 in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam"
[49] #6 __libc_start_main in "/lib64/libc.so.6"
[49] #7 ? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam"
[23] #6 __libc_start_main in "/lib64/libc.so.6"
[23] #7 ?? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam"
[ddcc24:mpi_rank_49][error_sighandler] Caught error: Floating point exception (signal 8)
[ddcc09:mpi_rank_23][error_sighandler] Caught error: Floating point exception (signal 8)
[ddcc24:mpispawn_3][readline] Unexpected End-Of-File on file descriptor 9. MPI process died?
doctorWho is offline   Reply With Quote
Personalization of mapFields and libsampling - Compilation issues saimat OpenFOAM Programming & Development 3 June 29, 2016 09:56
Strange random behaviour of mapFields blaise OpenFOAM Pre-Processing 0 November 3, 2014 10:37
two subdomain in fluid domain does not word (CFX) maxwellandi CFX 4 November 28, 2012 16:45
