interFoam always give 90 degree contact angle for nanodroplet
Old   June 19, 2016, 19:03
Default interFoam for small droplet
Jun Zhang
bigfeather is on a distinguished road
Hi All
I tried to use interFoam to simulate nanodroplet spreading on solid surface. However, I found that the interface is too diffusive.
Anyone has any ideas why interFoam doesn't work well for nanodroplet?
Many thanks,
Jun
bigfeather is offline   Reply With Quote
Old   June 20, 2016, 09:19
Saideep
Saideep is on a distinguished road
I had the same sort of problem with diffused interfaces using interFOAM at smaller dimensions.
I just struggle with micro meter scale but never went down to nano meter scale. However, I did find the interface diffusion to reduce when using interFOAM solver of OF_extend.
May be this could help you also. I did post a few results in the thread here:
http://www.cfd-online.com/Forums/ope...-behavior.html
Saideep
Saideep is offline   Reply With Quote
Old   June 21, 2016, 13:06
Jun Zhang
Originally Posted by Saideep View Post
Saideep
Hi Saideep
Thanks for this. Yes Foam-extend gives much sharper interface. It has solved my problem.
Do you know the difference of the interFoam code between OF 2.4 and Foam-extend?
Can I just replace the code of interFoam in OF 2.4 by that in Foam-extend?
Thanks,
Jun
Old   June 21, 2016, 13:54
Saideep
The reason behind this is yet unknown for me and it is really difficult to know the difference in code.
I guess also copying the code from FE to OF will not solve the problem until we debug what is causing this difference.
Also to add, FE uses structure of older version of OF(1.x, I guess) and the structure of code is lot different to the present OF versions.
Saideep
interfoam;contact angel
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 15:00
Slug Flow, interFoam, problems with Contact Angle PrzemekPL OpenFOAM Running, Solving & CFD 13 February 18, 2014 23:10
contact angle yan FLUENT 4 November 6, 2012 05:22
UDF for Contact Angle gandesk Fluent UDF and Scheme Programming 1 November 1, 2010 10:00
Contact Angle ata OpenFOAM 6 May 26, 2010 01:30
