Rosin Rammler d in SprayCloudProperties in sprayfoam
Old   June 17, 2016, 07:28
Default Rosin Rammler d in SprayCloudProperties in sprayfoam
saeed
saeedshayae is on a distinguished road
Hello CFDmans
As you know, We must set Several parameters in different files before the start of the simulation with OpenFOAM solvers (e.g. in constan, system folders).
My question is about Rosin Rammler parameter d in SprayCloudProperties in sprayFoam solver. Does anyone knows what the parameter d defines and how we can set value for it?
            sizeDistribution
                type        RosinRammler;
                RosinRammlerDistribution
                    minValue        1e-06;
                    maxValue        0.000120;
                    d               0.000020;//what is this????
                    n               3;
Best regards
Saeed
saeedshayae is offline   Reply With Quote
Old   June 17, 2016, 08:27
Alaska1964
Alaska1964 is on a distinguished road
Hi Saeed,
I am dealing somehow with the same problem. d is the droplet diameter which has the highest probabality.
Through which method do you get your data? Depending on number based or volume based particle size data your d can change.
By the way how do you define n? is it always 3??
Cheers,
Alex
Alaska1964 is offline   Reply With Quote
Old   June 17, 2016, 09:11
saeed
Originally Posted by Alaska1964 View Post
Hi Saeed,
Cheers,
Alex
thanks for reply
i don't understand really your answer. However, now when i want to simulate a simple hollow cone spray, what number i set to 'd'. i have no information about SMD and distribution before simulation and have information about injection pressure, orifice diameter, mass flow rate, injection time and ....
(meantime n is experimental parameter, but based on past research [1] it is usually 3 to 3.5.)
1- Z. Han, S. Parrish, P. V. Farrell and R. D. Reitz,Modeling atomization process of pressure-swirl hollow-cone fuel sprays, Atomization and Sprays 7(1997) 663-684.
Old   June 17, 2016, 09:59
Alaska1964
I think you should define it based on the particle size distribution (PSD) diagram.
d is the droplet diameter that has the largest probability which will be the mode of your density distribution diagram . (following link, page 18)
http://www.tfd.chalmers.se/~hani/kur...roject0122.pdf
I hope it can help.
Old   February 11, 2021, 06:25
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Rosin Rammler Distribution
HPE is offline   Reply With Quote
Problem with Rosin Rammler Chrisi1984 OpenFOAM Pre-Processing 1 February 24, 2021 12:53
Rosin Rammler Distribution mystix OpenFOAM Running, Solving & CFD 10 February 11, 2021 06:23
Post pro rosin rammler distribution jb pouillard FLUENT 0 September 25, 2015 19:45
Differences between OF2.2 and OF 2.3 in sprayFoam spraycloudproperties FWST OpenFOAM Running, Solving & CFD 1 February 13, 2015 07:53
Rosin Rammler Distribution AndiG FLUENT 1 March 7, 2007 11:56
