June 16, 2016, 08:31 |
boundary conditions
lynda
Rep Power: 17 |
HELLO !
I would like to impose the following boundary conditions for the two phase flow in a circular channel, The pressure is unknown at the inlet and outlet, but the velocity of the gas and the liquid are known at the inlet. knowing that I have two entrances: one for the gas and other one for the liquid, but I imposed a single output for both. I have some doubts about the boundary conditions, because the film liquid thickness at the exit is weird! since it should remains constant but it is decreasing and taking the approximately the same shape of the inlet. I would like to know if the problem is from boundary conditions at the exit ? then, could you please suggest for me such a suitable boundary conditions. NB: in attached files, boundary conditions and results at different time. THANK YOU, LYNA Last edited by lyna; June 17, 2016 at 10:18. |
July 19, 2016, 13:42 |
Pressure Boundary condition
lynda
Rep Power: 17 |
Hello
I would like to impose the following boundary conditions for the two phase flow in a circular channel, The pressure is unknown at the inlet and outlet, but the velocity of the gas and the liquid are known at the inlet. knowing that I have two entrances: one for the gas and other one for the liquid, but I imposed a single output for both. I have some doubts about the boundary conditions, because the film liquid thickness at the exit is weird! since it should remains constant but it is decreasing and taking the approximately the same shape of the inlet. then, could you please suggest for me such a suitable boundary conditions. THANK YOU, LYNA |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
