Generating the lift and drag coefficients with openFOAM
Old   June 14, 2016, 10:36
Default Generating the lift and drag coefficients with openFOAM
JackJewell is on a distinguished road
Hi, I am currently modelling a jet for a simulation program and need to generate the lift and Drag coefficients of the model at different mach numbers (specifically going transonic and peaking at mach 3.5) I'm using SimFlow which claims to be a windows version of openFOAM. how would I go about generating the lift and drag coefficients and should i just install a linux OS and install openFOAM on it? (not going to be easy in my case)
Thanks - Jack
JackJewell is offline   Reply With Quote
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
calculating lift and drag coefficients _ running in parallel Mike_star OpenFOAM Programming & Development 1 April 4, 2016 12:16
Can fluent get the lift and drag coefficients of the two walls (in different directio yuyuxuan FLUENT 8 January 10, 2014 21:13
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
