Flow pass 2D square cylinder using LES-channel 395 question
Old   May 30, 2016, 19:46
Question Flow pass 2D square cylinder using LES-channel 395 question
Bashar
Bashar is on a distinguished road
Dear All,
I am currently working on simulation for 2D square cylinder with Re=50000. I am trying to use LES with WALE SGS. I used the setup in the case "channel 395" in tutorial to build my own case, unfortunately I have been using openFoam for 3 months only, so I have a question regarding the data in the "0" folder inside this case: are they related to the WALE model? i.e can I use different setup for the variables inside this folder like ( P,U,K,B,..etc) from another model like Smagorinsky? the reason for that is related to the nature of this tutorial,"channel 395", for example the variable "k" is filled with data like shown below:
| \\ / O peration | Version: splitCyclic |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object k;
dimensions [ 0 2 -2 0 0 0 0 ];
internalField nonuniform List<scalar>
60000
0.000546979
0.000539726
0.000522268
0.000486501
0.00042352
0.000340779
0.000261349
0.000205418
0.000176593
0.000165225
0.000161396
0.00016139
0.000166469
0.000177507
0.000193931
0.000215604
0.000243705
0.000278988
5.34299e-05
5.57113e-05
5.80269e-05
6.14485e-05
6.61096e-05
7.18528e-05
7.79562e-05
8.41191e-05
boundaryField
bottomWall
type fixedValue;
value uniform 0;
topWall
type fixedValue;
value uniform 0;
sides1_half0
type cyclic;
sides2_half0
type cyclic;
inout1_half0
type cyclic;
inout2_half0
type cyclic;
sides2_half1
type cyclic;
sides1_half1
type cyclic;
inout1_half1
type cyclic;
inout2_half1
type cyclic;
Which I could not understand how to use my data in this file . and I saw that other LES tutorial is much easier to work with it when it come to the variables inside the "0" folder.
So sorry for this long questions , I hope some one have any advice.
Regards,
Bashar
Bashar is offline   Reply With Quote
Old   January 8, 2021, 02:53
sadsid is on a distinguished road
Hi Bashar,
I am facing the same thing. How you resolved this issue? did you get the idea for obtaining these non-uniform internal fields?
sadsid is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
Applyinga one phase LES to rectangular channel flow roi247 FLUENT 5 January 30, 2020 15:59
LES: Turbulent Channel Flow without initial solution (BC) DaSh OpenFOAM Running, Solving & CFD 21 February 8, 2015 17:09
LES of a turbulent channel flow stays laminar liu OpenFOAM Running, Solving & CFD 2 May 27, 2010 14:53
Slug flow in square channel PaulC FLUENT 0 December 5, 2005 03:03
