May 25, 2016, 21:01 |
Starting vortex in airfoil
Alejandro
Rep Power: 10 |
I have to simulate with Openfoam an airfoil with angle of attack impulsively started from rest to a velocity U. This has to give me a starting vortex with the opposite circulation with respect to the circulation around the airfoil. I am considering an incompressible,two-dimensional,transient and laminar problem. I have done the mesh using gmsh. In Openfoam, I am using the PimpleDyMFoam as solver because I think that it could be the most appropiate solver for this problem. However, when I simulate the problem from 0s to 1s with a time step of 0.0001, the simulation gives me some problems at the end. Moreover, I can see that the Courant number is high and not converges when the time is close to 1s. I would like to ask you some questions: 1. What can I do to reduce the Courant number? 2. Do you think that I am planning the problem well (using the right solver, using the right hypothesis,etc)? 3. Do you suggest me using gmsh to do the mesh? 4. How could I know when the simulation is well done? Thanks in advance for your help. |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 17:17 |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 13:42 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 18:27 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 10:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 10:26 |
