Simulation of generated field of permanent magnet
Old   May 24, 2016, 04:47
Default Simulation of generated field of permanent magnet
DUCHESNE
jim53 is on a distinguished road
Hello everyone, I installed the last version of OpenFOAM on linux (Xubuntu 14.04) because I want to perform a simulation of the magnetic fields generated by a permanent magnet in a volume of air.
I am new in the simulation but I read that OpenFOAM had magneticFoam solver to simulate the permanent magnet.
My study case is to know the magnetic fields generated by a permanent dipole magnet whose dimensions are:
- Length: 10mm
- Width: 5 mm
- Height: 5 mm
- Material: Neodymium Iron Boron
The volume in which the generated magnetic field has to be calculated:
- Length: 50mm
- Width: 50mm
- Height: 50mm
I have looked for detailled tutorial but I have not found a simple study case to understand the simulation procedure and parameters. I hope that someone will be able to help me to solve.
Thanks you for advance.
jim53 is offline   Reply With Quote
Old   May 24, 2016, 05:49
akidess's Avatar
Anton Kidess
http://www.cfd-online.com/Forums/ope...neticfoam.html
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 24, 2016, 07:10
DUCHESNE
Thank you for your reply.
I have downloaded the magSandbox example to understand how the study case is built but unfortunately, I have an error when I run "./Allrun".
The error is recorded in the file "log.magneticFoam" (See attached file)and I don't know how to solve this problem to see the result of this study case.
Does someone know how correct this error?
permanent magnet, simulation
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
"Particle track" does not get generated in the Simulation tree Catostrof STAR-CCM+ 7 August 4, 2016 07:32
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 19:05
gradient of electric field simulation with ansys multiphysics mahdi-upc ANSYS 0 October 17, 2013 16:21
Generated Rotor(G-rotor) type oil pump simulation Abhishek Thakur FloEFD, FloWorks & FloTHERM 1 November 17, 2011 10:56
