How to calculate the particles concentration?
Old   May 18, 2016, 06:09
Default How to calculate the particles concentration?
Ping Chang
chpjz0391 is on a distinguished road
Hey Foamers,
I am using simpleReactingParcelFoam to simulate the particles at steadystate.
The simulation goes well. I can get the particle mass, and number. However, I have a qustion,How can I get the concentration (kg/m^3)of the particles for a cell. I know I need to recompile the solver, and I have some codes about the concentration, but I am poor at C++. Could someone tell me how should I compile my solver in the main programme and createfield.H
the main.H
/*#################calculate the particle concentration, begin.################*/
    forAll(Conc,i)
        Conc[i] = vector(0.0,0.0,0.0);
    forAllConstIter(typename basicKinematicTypeCloud, kinematicCloud, iter)
        const parcelType& p = iter();
        const label cellI = p.cell();
        Fluxs[cellI]+=p.nParticle()*p.mass();
    forAll(mesh.V(),i)
        Conc[i]/=mesh.V()[i];
	/*#################calculate the particle velocity, end.################*/
Here is the cold for the field.H
/*##########################construct solid conc field.mass Concentration of the lagrangian particle [kg/(m^2*s)]##############*/
    Info<< "Creating field solid Conc\n" << endl;  //
    volVectorField Conc
        IOobject
            "Conc",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedVector("zero", dimMass/dimVolume, vector::zero)
	/*##########################################end######################################################################*/
chpjz0391 is offline   Reply With Quote
Old   May 23, 2016, 23:30
Ping Chang
Hi all,
any suggestion?
Old   May 24, 2016, 10:29
Brian Willis
Dipsomaniac is on a distinguished road
Hi Ping
Firstly concentration will be a volScalarField and not a volVectorField. Correct me if I am wrong. To compile a new solver you will need to edit the options and make files and then compile it. There are good tutorials online explaining how to compile new solvers. Google adding a scalar transport equation to simpleFoam or interFoam.
Regards,
Brian
Dipsomaniac is offline   Reply With Quote
Old   May 24, 2016, 22:05
Ping Chang
Originally Posted by Dipsomaniac View Post
Hi Ping
Regards,
Brian
Hi Brian,
You are right, concentration is a volScalarField. I have compiled the solver, now I get the error information like this. I know little about C++ , could you tell me how should I modify this solver.
This is main solver(based on simpleReactingParcelFoam):
基于simpleReactingParcelFoam改的主程序:
#include "fvCFD.H"
#include "turbulentFluidThermoModel.H"
#include "basicReactingMultiphaseCloud.H"
#include "rhoCombustionModel.H"
#include "radiationModel.H"
#include "IOporosityModelList.H"
#include "fvIOoptionList.H"
#include "SLGThermo.H"
#include "simpleControl.H"
#include "basicKinematicCloud.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "readGravitationalAcceleration.H"
    simpleControl simple(mesh);
    #include "createFields.H"
    #include "createRadiationModel.H"
    #include "createClouds.H"
    #include "createMRF.H"
    #include "createFvOptions.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        parcels.evolve();
        // --- Pressure-velocity SIMPLE corrector loop
         /*   #include "UEqn.H"
            #include "YEqn.H"
            #include "EEqn.H"
            #include "pEqn.H" */
    /*#################calculate the particle concentration, begin.(below is my code)################*/
        pmc[cellI]+=p.nParticles()*p.mass0();
        pmc /=mesh().V();
     /*#################calculate the particle concentration, end.################*/
        turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
then is hte creatFields.H
Info<< "Creating combustion model\n" << endl;
autoPtr<combustionModels::rhoCombustionModel> combustion
    combustionModels::rhoCombustionModel::New(mesh)
rhoReactionThermo& thermo = combustion->thermo();
thermo.validate(args.executable(), "h", "e");
SLGThermo slgThermo(mesh, thermo);
basicSpecieMixture& composition = thermo.composition();
PtrList<volScalarField>& Y = composition.Y();
const word inertSpecie(thermo.lookup("inertSpecie"));
if (!composition.contains(inertSpecie))
    FatalErrorIn(args.executable())
        << "Specified inert specie '" << inertSpecie << "' not found in "
        << "species list. Available species:" << composition.species()
        << exit(FatalError);
volScalarField& p = thermo.p();
const volScalarField& T = thermo.T();
const volScalarField& psi = thermo.psi();
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    thermo.rho()
Info<< "\nReading field U\n" << endl;
volVectorField U
    IOobject
        "U",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
    mesh
    Info<< "Reading field pmc\n" << endl;
    volScalarField pmc
        IOobject
            "pmc",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
        mesh
	/*##########################construct solid concentration field.mass  of the lagrangian particle [kg/(m^3)]##############*/
#include "compressibleCreatePhi.H"
mesh.setFluxRequired(p.name());
dimensionedScalar rhoMax
    dimensionedScalar::lookupOrDefault
        "rhoMax",
        simple.dict(),
        dimDensity,
        GREAT
dimensionedScalar rhoMin
        "rhoMin",
        simple.dict(),
        dimDensity,
        0
Info<< "Creating turbulence model\n" << endl;
autoPtr<compressible::turbulenceModel> turbulence
    compressible::turbulenceModel::New
        rho,
        U,
        phi,
        thermo
// Set the turbulence into the combustion model
combustion->setTurbulence(turbulence());
Info<< "Creating multi-variate interpolation scheme\n" << endl;
multivariateSurfaceInterpolationScheme<scalar>::fieldTable fields;
forAll(Y, i)
    fields.add(Y[i]);
fields.add(thermo.he());
volScalarField dQ
    IOobject
        "dQ",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    mesh,
    dimensionedScalar("dQ", dimEnergy/dimTime, 0.0)
The error inforamation:
simpleParticlesFoam.C: In function ‘int main(int, char**)’:
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: invalid type in declaration before ‘::’ token
Container::const_iterator iter = (container).begin(); \
simpleParticlesFoam.C:89:5: note: in expansion of macro ‘forAllConstIter’
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: expected ‘;’ before ‘::’ token
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: ‘::const_iterator’ has not been declared
simpleParticlesFoam.C:89:71: error: expected ‘;’ before ‘iter’
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:35: note: in definition of macro ‘forAllConstIter’
simpleParticlesFoam.C:89:71: error: ‘iter’ was not declared in this scope
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:52: error: expected primary-expression before ‘)’ token
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:61: error: expected ‘)’ before ‘;’ token
simpleParticlesFoam.C:89:30: warning: unused variable ‘basicKinematicTypeCloud’ [-Wunused-variable]
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:9: note: in definition of macro ‘forAllConstIter’
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:466:9: note: in definition of macro ‘forAllConstIter’
iter != (container).end(); \
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:466:27: error: expected primary-expression before ‘)’ token
/opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:468:5: error: expected ‘;’ before ‘)’ token
simpleParticlesFoam.C:97:20: error: no match for call to ‘(Foam::fvMesh) ()’
pmc /=mesh().V();
In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:7:0,
from simpleParticlesFoam.C:34:
/opt/openfoam30/src/finiteVolume/lnInclude/fvMesh.H:79:7: note: candidate is:
class fvMesh
In file included from /opt/openfoam30/src/OpenFOAM/lnInclude/HashTable.H:549:0,
from /opt/openfoam30/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:41,
from /opt/openfoam30/src/OpenFOAM/lnInclude/token.H:49,
from /opt/openfoam30/src/OpenFOAM/lnInclude/UListIO.C:28,
from /opt/openfoam30/src/OpenFOAM/lnInclude/UList.C:225,
from /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:474,
from /opt/openfoam30/src/OpenFOAM/lnInclude/List.H:43,
from /opt/openfoam30/src/OpenFOAM/lnInclude/labelList.H:48,
from /opt/openfoam30/src/OpenFOAM/lnInclude/UPstream.H:42,
from /opt/openfoam30/src/OpenFOAM/lnInclude/Pstream.H:42,
from /opt/openfoam30/src/OpenFOAM/lnInclude/parRun.H:35,
from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:4,
/opt/openfoam30/src/OpenFOAM/lnInclude/HashTableI.H:145:11: note: T& Foam::HashTable<T, Key, Hash>:perator()(const Key&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
inline T& Foam::HashTable<T, Key, Hash>:perator()(const Key& key)
/opt/openfoam30/src/OpenFOAM/lnInclude/HashTableI.H:145:11: note: candidate expects 1 argument, 0 provided
In file included from simpleParticlesFoam.C:57:0:
createFields.H:27:23: warning: unused variable ‘T’ [-Wunused-variable]
createFields.H:28:23: warning: unused variable ‘psi’ [-Wunused-variable]
In file included from simpleParticlesFoam.C:62:0:
/opt/openfoam30/src/finiteVolume/lnInclude/initContinuityErrs.H:37:8: warning: unused variable ‘cumulativeContErr’ [-Wunused-variable]
scalar cumulativeContErr = 0;
make: *** [Make/linux64GccDPInt32Opt/simpleParticlesFoam.o] Error 1
Old   May 24, 2016, 22:56
Joseph Urich
jurich is on a distinguished road
Hello Ping,
OpenFOAM version 3.0.x has something similar built in: it can calculation a void fraction. Take a look at src/lagrangian/intermediate/submodels/cloudFunctionObjects/VoidFraction to see how it works.
It is activated by adding the following
cloudVoidFraction1
type voidFraction;
to the cloudFunctions section at the end of your particle dictionary.
This is m^3/m^3. If you really need kg/m^3, you would need to copy that class and then modify it to include the particle density. It needs to be done within the particle tracking call, not in your main solver.
I hope that helps.
jurich is offline   Reply With Quote
Old   May 24, 2016, 23:02
Ping Chang
Originally Posted by jurich View Post
Hello Ping,
cloudVoidFraction1
type voidFraction;
I hope that helps.
Hi,Joseph Urich
I am new to OpenFoam, could you give me more details about this function.
Could you please post some code ,so I can know how to modify.
Thank you
Kind Regards.
Ping
Old   October 23, 2019, 04:10
Hailong
nilvxingren is on a distinguished road
Hello Ping,
Have you solved this problem? I calculated a case use MPPICFoam, and need to show the cloud of particle concentration.
nilvxingren is offline   Reply With Quote
Old   August 8, 2021, 09:27
Smile use 'voidFraction' in 'cloudFunctions' of your cloudProperties dictionary
Sourav Mandal
sourav90 is on a distinguished road
Originally Posted by nilvxingren View Post
Hello Ping,
The functionObject named 'voidFraction' can be used to calculate particle concentration. For details, check this thread:
output lagrangian particle volume fraction "reactingParcelFoam"
sourav90 is offline   Reply With Quote
Increasing particles splashed yoooodarulez Fluent Multiphase 2 August 3, 2013 07:22
Concentration of particles in sub-volume kathryn FLUENT 0 September 20, 2010 08:58
particles model ati_ros61 FLOW-3D 3 December 6, 2009 17:03
initial concentration in multicomponent mixtures isidro Siemens 0 April 26, 2004 08:40
how to calculate volume fraction of particles from x. simth FLUENT 2 April 26, 2001 16:40
