May 12, 2016, 18:16 |
foamDataToFluent cannot shown in Fluent
Howar
Rep Power: 11 |
When I use the foamDataToFluent, there are always some problem:
1 if I only voncert P,T,U , the .dat has no problem in Fluent. However if I added species like O2, it always shows error when using fluent (fluentError: received a fatal signal (Segmentation fault)) 2 The T field shown in Fluent is uniform 300K, which is different from the original results in OpenFOAM Does anyone have any idea? Thank you. |
foamdatatofluent, species, temperature |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Graph is not shown in fluent | emre_87 | FLUENT | 2 | December 20, 2015 13:58 |
batch mode fluent - beginner | CompIng | FLUENT | 1 | November 30, 2015 11:48 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
