May 9, 2016, 12:37 |
omega wilcox definition
Rep Power: 10 |
I'm using k-omega SST model in Low-Re mode so without wall functions.
I set omega with fixedValue calculated with wilcox's formula: omega = 6*nu/(0.075*y^2) in which y should be the first cell center nearest to wall. How i can calcaulate this? Is there an utility for this? |
May 11, 2016, 18:13 |
Clara
Rep Power: 16 |
Dear giammy92,
What do you need to calculate? y or omega? or you want to calculate omega within the code directly? Cheers! |
May 11, 2016, 19:37 |
Rep Power: 10 |
Hi risku9, I want calculate omega with wilcox formula at wall because I think that is more accurated compared to omegaWallFunction. I need to know y in formula that should be the first cell center right? Is there an utility to calculate it?
May 11, 2016, 19:48 |
Clara
Rep Power: 16 |
Hey!
If what you want to get is y, I think you can find it in the wall function definition of omegaWallfunction: src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/omegaWallFunctions/omegaWallFunctions You can find this piece of code: const scalarField& y = turbulence.y()[patchI]; Which I believe refers to the nearWall distance, as if you look into the C++ documentation of OpenFOAM: http://openfoam.github.io/Documentat...ml/a01744.html Looking for turbulenceModel::y() and clicking on it you will reach: http://openfoam.github.io/Documentat...ce.html#l00157 where it explains: //- Return the near wall distances 158 const nearWallDist& y() const 159 { 160 return y_; 161 } So I think if you use that turbulence.y() as in the omegaWallFunction now, you should be able to get to do what you would like! I hope this helps! =) |
May 12, 2016, 08:11 |
Rep Power: 10 |
Sorry i haven't understood well what i have to do to obtain near wall distance.
May 12, 2016, 13:27 |
Clara
Rep Power: 16 |
Hey,
So I think you would just need to create a new wall function, in which you set that omega to the value you want. I was checking the original OmegaWallFunction in the code in the folder of installation of openfoam: OpenFOAM/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/omegaWallFunctions/ And it is almost already what you are looking for as beta1_ = 0.075, you would just need to comment the omegaLog component. If look in line 234 from omegaWallFunction.C file: // Set omega and G forAll(nutw, faceI) { label cellI = patch.faceCells()[faceI]; scalar w = cornerWeights[faceI]; scalar omegaVis = 6.0*nuw[faceI]/(beta1_*sqr(y[faceI])); scalar omegaLog = sqrt(k[cellI])/(Cmu25*kappa_*y[faceI]); omega[cellI] += w*sqrt(sqr(omegaVis) + sqr(omegaLog)); G[cellI] += w *(nutw[faceI] + nuw[faceI]) *magGradUw[faceI] *Cmu25*sqrt(k[cellI]) /(kappa_*y[faceI]); } |
Behaviour of the kOmegaSST in a steady-state case | Max1234 | OpenFOAM Running, Solving & CFD | 18 | October 31, 2018 09:03 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 14:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
Definition of omega | jpo | FLUENT | 4 | April 7, 2009 16:06 |
