Openfoam - Run Wind Simulations in Different Direction
Old   May 9, 2016, 06:30
Default Openfoam - Run Wind Simulations in Different Direction
KYA123
YK123 is on a distinguished road
Recently, I have tried running the simulation in North direction and it succeeds. But when I tried to run the same simulation in S, NE and SE direction. But the error message keeps popping out as listed below:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model realizableKE
realizableKECoeffs
Cmu 0.09;
A0 4;
C2 1.9;
sigmak 1;
sigmaEps 1.2;
No finite volume options present
SIMPLE: convergence criteria
field p tolerance 1e-005
field U tolerance 1e-005
field k tolerance 1e-005
field epsilon tolerance 1e-005
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1001
DICPCG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1001
time step continuity errors : sum local = nan, global = nan, cumulative = nan
DILUPBiCG: Solving for epsilon, Initial residual = nan, Final residual = nan, No Iterations 1001
DILUPBiCG: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1001
ExecutionTime = 240.417 s ClockTime = 240 s
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: D:/CFD-Project/Test/Trial_S/OpenFOAM/system/data.solverPerformance.U at line 0.
From function operator>>(Istream&, Scalar&)
in file lnInclude/../primitives/Scalar/Scalar.T.C at line 93.
FOAM exiting
Kindly advise on how to solve the problem.
Thanks
YK123 is offline   Reply With Quote
Old   May 9, 2016, 07:33
g.freeman is on a distinguished road
Originally Posted by YK123 View Post
Create time
Reading field p
Reading field U
realizableKECoeffs
Cmu 0.09;
A0 4;
C2 1.9;
sigmak 1;
sigmaEps 1.2;
Starting time loop
Time = 1
FOAM exiting
Thanks
can you post your BC? From the error seems it wants a scalar value but it finds a nan
g.freeman is offline   Reply With Quote
Old   May 10, 2016, 03:42
KYA123
Below is my boundary condition:
1) For Wall on all building geometries,
P = zero gradient,
U = fixedValue with (x y z) = uniform 0,
Epsilon = epsilonWallFunction, uniform 0.1
K = kqRWallFunction, uniform 0.1
Nut = nutkWallFunction, Value 0
2) For Wall on blockmesh bottom,
P = zero gradient,
3) For Inlet on blockmesh front,
P = zero gradient,
U = atmBoundaryLayerInlet (0m/s)
Epsilon = MixingLengthFrequency 1m
K = turbulentintensityKineticenergyInlet 5%
Nut = Calculated Value 0
4) For Outlet on blockmesh back,
P = fixedValue, uniform 0
U = zeroGradient
Epsilon = zeroGradient
K = zeroGradient
5) For Slip on blockmesh top
All P, U, Epsilon, K and Nut = zeroGradient
Thanks and Best Regards
Old   May 16, 2016, 08:38
KYA123
http://www.cfd-online.com/Forums/ope...direction.html
Kindly advise on how to solve the problems urgently.
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
atmospheric boundary layer (ABL) - implementing wind direction rob3rt 0ng OpenFOAM Running, Solving & CFD 0 November 4, 2015 21:57
3D horizontal axis wind turbine, OpenFOAM beginner tareqkh OpenFOAM 0 July 16, 2015 08:19
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
