May 4, 2016, 15:58 |
UncoupledKinematicParcelFoam
DS
Rep Power: 10 |
Good Morning, I would ask some informations about the uncoupledKinematicParcelFoam function. In particular about the ParcelBasisType value defined in the kinematicProperties. I know that there are three possibilities: numbered, mass and fixed. My model works with mass value if only I impose an higher MassTotal value than required. On the other hand, the model works with the correct massTotal value with fixed value. I would ask you some clarification about the difference between them using OpenFoam 3.0.1. thank you very much...Best Regards...DS
kinematicproperties, parcelbasistype, uncoupled approch |
