Looking for advice for fluid-structure simulation |
March 29, 2016, 08:21 |
Rep Power: 10 |
Dear OpenFoam users,
Recently, we have a new project and need to calculate the piler's (array of pliers, microfluidics) deformation due to surface tension. I used to do simulations only for multiphase flow and just consider solid as a rigid solid boundary. I've never dealt with deformable solid. Can anyone give me some advice? We'd like to start with some commercial or open-source software. Can OpenFoam do this kind of simulation? fluid-structure coupling? Thank you very much guys Keywords: fluid structure, coupling solvers, surface tension, incompressible flow, microfluidics |
March 29, 2016, 18:57 |
Have a look at the following link concerning OpenFOAM FSI capabilities:
http://openfoam-extend.sourceforge.n...re_Interaction https://openfoamwiki.net/index.php/E...re_interaction In OpenFOAM Extend Project their are several FSI solver like: icoFsiFoam (incompressible flow & small deformations) icoFsiElasticNonLinULSolidFoam (incompressible flow & large deformations) I am not sure about the multiphase capabilities together with FSI!!! |
April 6, 2016, 13:19 |
Damon Lee
Rep Power: 12 |
I have been simulating some things using the fsi library in foam-extend 3.1.
It can definitely do multiphase flow but you will have to make add that fluid solver yourself by copying something like interFoam and putting it into that FSI library. They made it nice and modular, I have so far done it successfully with cavitatingFoam. With interFoam watch out for the diffusive effect at the interface, I'm no expert at this but having seen presentations by the guy who made isoAdvector it seems all the commercial stuff and interFoam-MULES don't do very well, that being said you do have surface tension there so maybe there is no issue. https://www.youtube.com/watch?v=Dv_HIHJ-Xkc They are working on a release for foam-extend 3.2 I think. The solvers that you see there form the basic installation have been superseded by this library, you can download it from the extend-bazaar folder in the foam directory, remember it only compiles with foam-extend 3.1 for now |
Problem in initializing transient simulation with a finer mesh | sidd | CFX | 8 | April 29, 2016 03:25 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 05:44 |
Requiring some help regarding tornado simulation | amarjogot | Main CFD Forum | 0 | June 20, 2013 13:26 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
