February 15, 2016, 16:04 |
LES Averaging
Narmin
Rep Power: 12 |
I have done a les simulation using rhopimplefoam. I want to compare it with experimental data. Therefore, i should do averaging. I saw that I can do it by adding a small script to controlDict, my questions are, which fields I should add? I have added, p, U and T. Will I get average of temperature, presure and velocity? How can I post process the results? When I open paraFoam and see the contours of for example temperature, are they the mean contours or instantaneous? How can I load the mean contours? |
February 16, 2016, 05:39 |
#2 | |
David GISEN
Rep Power: 17 |
2.-4. OpenFOAM generates new fields, e.g. UMean, additional to U. You can load them in ParaView along with the instantaneous fields. I'm not sure what you mean with "contours". If you want to visualize isolines, you can apply filters on every field you loaded separately. Cheers, David |
February 16, 2016, 07:15 |
Narmin
Rep Power: 12 |
Thanks David,
I, however, still can't figure out, how to load mean and instantaneous values seperately into paraview. |
How to do spatial averaging - LES pipe flows ? | Dan1788 | OpenFOAM Running, Solving & CFD | 0 | December 12, 2014 15:50 |
averaging in les | klilla | OpenFOAM | 2 | February 10, 2010 03:29 |
Averaging LES | iko | FLUENT | 3 | July 3, 2008 06:55 |
Start of averaging in LES | fab | Main CFD Forum | 2 | June 16, 2005 05:53 |
Averaging Method for LES | Kim | Main CFD Forum | 0 | November 21, 2001 08:18 |
