(incompressible) interFoam - where is the density in the k, epsilon and continuity eq
Old   December 22, 2015, 15:40
Default (incompressible) interFoam - where is the density in the k, epsilon and continuity eq
idefix is on a distinguished road
the following equation for epsilon is used to calculate this value when using the k-epsilon turbulence model
fvm::ddt(epsilon_)
+ fvm::div(phi_, epsilon_)
-fvm::Sp(fvc::div(phi_), epsilon_)
- fvm::laplacian(DepsilonEff(), epsilon_)
C1_*G*epsilon_/k_
- fvm::Sp(C2_*epsilon_/k_, epsilon_)
Now I want to use the k-epsilon turbulence model together with the interFoam-solver, which is incompressible.
Do I have to include the densitiy for example in
fvm::ddt(epsilon_)
--> fvm::ddt(epsilon_ * density) ?
I am asking because the solver is described in the UserGuide as solver for two incompressible fluids. That is clear for pure gas and pure liquid phase.
But what happens for the area where the interface is?
Is it necessary there to add the density in the epsilon-equation?
I foundn in Rusche´s thesis (eq. 3.25) an explanation that the velocity is weighted with the liquid volume fraction. Is this valid for k and epsilon too?
If this is the case where does it happen in the code?
What happens to the contiunity equation?
Is it:
d rho / dt + d (rho * u_i)/ dx_i ?
Thanks a lot for your help
idefix is offline   Reply With Quote
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
