PrimitivePatch movePoints() didnt move the points
Old   July 21, 2015, 10:57
Default PrimitivePatch movePoints() didnt move the points
Tian Tang
tiat is on a distinguished road
Hi Foamers,
I am trying to use a PrimitivePatch to do some manipulations of point movements on a specific patch(surface). I had the prescibed pointField "pointDisp" and i call the function:
mySeaBottomPatch.movePoints(pointDisp);
However i checked the points coordinates before and after the movePoints, they are exactly the same.
I looked into the source code of PrimitivePatch.C and found the following code:
template<class Face,template<class> class FaceList,class PointField,class PointType>
void Foam::PrimitivePatch<Face, FaceList, PointField, PointType>::movePoints(const Field<PointType>&)
if (debug)
Pout<< "PrimitivePatch<Face, FaceList, PointField, PointType>::"<< "movePoints() : "<< "recalculating PrimitivePatch geometry following mesh motion"<< endl;
clearGeom();
it seems that the movePoints() function actually didn't move the points??? as i understand the clearGeom() function is just to clean the old points info?
I tried to look into other places to get some info of movePoints(), like polyMesh.movePoints(). However i still didn't manage to make things work. Anybody can help for such issue? I would appreciate any ideas.
Tian
tiat is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
[mesh manipulation] DynamicMesh - Move internal points nucat OpenFOAM Meshing & Mesh Conversion 2 September 6, 2014 09:54
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
