July 20, 2015, 08:10 |
Fixed flow rate with cyclic BC
Marc-Aurele
I would like to know if it is possible to fix a flow rate with a cyclic BC. My goal is to have a fully developed flow on all the pipe (= without an entrance region). I use OpenFoam 2.2.2 Thank you Marc-Aurčle |
July 27, 2015, 14:03 |
Cyprien
Rep Power: 18 |
Hi Marc-Aurele,
you can go to through this document https://web.stanford.edu/~csoulain/PORE_SCALE/Chap2.pdf from page 11 to 13. The idea is to add an average pressure drop as a source term in your momentum equation. The pressure you solve is then the deviation to the average pressure. Hence, you can consider cyclic condition to the "pressure" field. Cheers, Cyprien |
cyclic boundry condition, flow rate, fully developed flow |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Cyclic boundary conditions concerning channel with constant flow rate | pascool | OpenFOAM Pre-Processing | 1 | November 16, 2012 13:04 |
Fixed Flow rate and outlet Continuity Problem | mrshb4 | OpenFOAM | 1 | March 10, 2012 14:32 |
How to calculate phase flow rate? | sangramroy | FLUENT | 0 | January 11, 2012 13:02 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
