Rep Power: 0 ![]() |
at the inlet there is the turbulent inlet boundary condition. Now I like to calculate/measure the intensity at L/4, L/2, 3L/4 and L (L = length of the pipe). Could you give me a tip? Thank you! |
Nicole Andrew
Rep Power: 11 ![]() |
Hi Simon,
Do you know what equation you would like to use to calculate the turbulence intensity? I remember looking for it a while back but I could not figure out exactly what OpenFOAM uses. I am by no means a turbulence expert, but if you have an equation for it then I might be able to help you implement that in OpenFOAM. Have you looked at the sample utility? I have not used it myself yet. Regards, Nicole |
Blanco
Rep Power: 17 ![]() |
it really depends on what kind of turbulence modelling you are using. If you are using rans equations then you can choose different turbulence models, as k-eps, k-omega, etc. If you have k available in your turb model then you can calculate turb intensity by deriving if from k value, because k is turbulence kinetic energy and it's directly linkend to turb intensity. You can sample the k value where you want using the "sample" utility with a sampleDict. If otherwise you are doing Les, you have turb components of velocities, therefore you can directly calculate turb intensity. Best |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Turbulence length scale | Leonpolou | FLUENT | 2 | January 23, 2013 07:26 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
turbulence calculation in programming | flakid | OpenFOAM Programming & Development | 1 | October 29, 2011 10:22 |
