value uniform 1/0 meaning for contact angle boundary condition? |
May 20, 2015, 13:31 |
Saideep
Rep Power: 12 |
Hi Foamers;
I have a rather basic question. I am dealing with two phase flows using the interFOAM solver. I try to implement the boundary condition for the contact angle at the top and bottom layers of my rectangular domain. I use the following boundary condition: top { type constantAlphaContactAngle; limit gradient; theta0 0; value uniform 1; } I am curious to know what does the value uniform 1 mean in this case? I even changed the value to uniform 0 and I have the same set of results. I would be happy if anyone could clarify this. Thanks. |
May 20, 2015, 14:39 |
value is the fixed angle of contact to the solid surface.
Saideep
Rep Power: 12 |
Sorry guys;
it was so easy!! The value over there is for the contact angle. 0 - 180 are valid. 0 is not considering any contact angle effects and any value of alpha depends on the condition for your run. Could be useful for any others. Sorry to bother you!! |
March 6, 2019, 06:57 |
Daniele Catucci
Rep Power: 7 |
Dear Saideep
If I understand well, putting theta0=45 and " value uniform 0" I will have a contact angle of 0. Instead, by setting "value uniform 1" I will have a contact angle of 45. That right? |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 11:54 |
interFoam | Hydraulic Jump | Correct boundary condition p_rgh | pythag0ra5 | OpenFOAM Running, Solving & CFD | 17 | September 5, 2014 05:31 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
Boundary condition setting for non-premixed combustion using reactingFoam | skyopener | OpenFOAM | 0 | May 23, 2010 23:55 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 12:32 |
