Tutorial Not Running In OpenFOAM
Old   January 19, 2015, 22:26
Default Tutorial Not Running In OpenFOAM
Alex
H0T_S0UP is on a distinguished road
Hello, I am new to openfoam and I have enrolled in the first course offered by TechnicalCourses.net. I am trying to run the "laplacianfoam" case and receive the following error "Command not found"
The steps I have taken are as follows:
After setting up openfoam
1) change directory
=> cd $FOAM_RUN/tutorials/basic/laplacianFoam/flange
works fine.
2)convert ansys mesh to openfoam mesh
=> ansysToFoam flange.ans –scale 0.001
works fine.
3)execute the solver
=> laplacianfoam
error ensues.
This a copy of the command line
skankatron@skankatron-Q551LN:~/OpenFOAM/skankatron-2.3.1/run/tutorials/basic/laplacianFoam/flange$ laplacianfoam
laplacianfoam: command not found
Any idea what is wrong? I ran the tutorial case given on the openfoam website on the install page and did not have any issues. Keep in mind I am really new to linux and this software. I am also going at this alone so any help is appreciated.
H0T_S0UP is offline   Reply With Quote
Old   January 20, 2015, 04:23
blacksquirrel is on a distinguished road
The correct command should be laplacianFoam, with a capital "F"
blacksquirrel is offline   Reply With Quote
Old   January 20, 2015, 17:58
Alex
Doh! Must have been tired when I was finishing that assignment. Worked fine, thanks!
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
Running in parallel with a machine that doesn't have OpenFOAM aujamal20 OpenFOAM Running, Solving & CFD 1 September 14, 2013 11:08
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Is OpenFOAM tutorial cases valid? j-avdeev OpenFOAM Running, Solving & CFD 3 September 19, 2012 16:45
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
