Creating a customized software tool using OpenFoam libraries |
January 19, 2015, 06:01 |
Vishnu C
Rep Power: 13 |
Hi all,
I knew that a software tool can be created using Open Cascade for CAD applications, similarly can I create a software tool for CFD applications using Open Foam libraries, if so can you please refer some links or any documents? |
January 19, 2015, 08:56 |
Armin
Rep Power: 19 |
Yes you can, but the documentation is the tricky part.
There is the official "OpenFOAM Programmer's Guide" (google will help you find it), but that is probably not exactly what you are looking for. Otherwise there are a lot of tutorials scattered around on the web. A very good starting point is the "OpenFOAM programming tutorial" by Tommaso Lucchini, you should find that one on the CHALMERS web pages. |
cfd, openfoam |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 07:54 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 23:44 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 09:15 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 12:51 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 09:50 |
