uniformTotalPressure BC problems
Old   January 4, 2015, 03:54
Unhappy uniformTotalPressure BC problems
Slanth is on a distinguished road
Hello, everyone. I want to implement a time-varying total pressure BC. So I use the uniformTotalPressure in OpenFOAM-2.2.2. The velocity boundary is pressureInletOutletVelocity. But as time going on, I always obtain the negative temperature, which is insane.
However, if I just use totalpressure BC without time-varying properties. The simulation is ok. The case aims at solving compressible flow using LES. Piso is used.
Any assistance is appreciated, thanks very much.
Slanth is offline   Reply With Quote
Old   January 4, 2015, 04:22
The pressure boundary and velocity boundary are belows
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
location    "492";
object      p;
dimensions      [--2 0 0 0 0];
internalField   uniform 118847;
boundaryField
intake_intake
type            uniformTotalPressure;
U               U;
phi             phi;
rho             none;
psi             psi;
gamma           1.4;
pressure        tableFile;
tableFileCoeffs
fileName     "$FOAM_CASE/constant/p_intake"
outOfBounds  clamp
exhaust_exhaust
U               U;
phi             phi;
rho             none;
psi             psi;
gamma           1.4;
pressure        tableFile;
tableFileCoeffs
fileName     "$FOAM_CASE/constant/p_Exhaust"
outOfBounds  clamp
intake_wall_intake_wall
type            zeroGradient;
valve1_seat_valve1_seat
type            zeroGradient;
exhaust_wall_exhaust_wall
type            zeroGradient;
valve2_seat_valve2_seat
type            zeroGradient;
cylinderHead
type            zeroGradient;
SparkPlug_SparkPlug
type            zeroGradient;
stem_wall1_stem_wall1
type            zeroGradient;
stem_wall2_stem_wall2
type            zeroGradient;
piston
type            zeroGradient;
liner
type            zeroGradient;
valve1_stem_valve1_stem
type            zeroGradient;
valve1_top_up_valve1_top_up
type            zeroGradient;
valve1_top_down_valve1_top_down
type            zeroGradient;
valve1_bottom_valve1_bottom
type            zeroGradient;
valve2_stem_valve2_stem
type            zeroGradient;
valve2_top_up_valve2_top_up
type            zeroGradient;
valve2_top_down_valve2_top_down
type            zeroGradient;
valve2_bottom_valve2_bottom
type            zeroGradient;
valve2Baffle_region0
type            zeroGradient;
valve2Baffle_region0_slave
type            zeroGradient;
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volVectorField;
location    "492";
object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
intake_intake
type            pressureInletOutletVelocity;
value           uniform (0 0 0);
type            fixedValue;
type            fixedValue;
exhaust_exhaust
type            fixedValue;
type            fixedValue;
cylinderHead
type            fixedValue;
SparkPlug_SparkPlug
type            fixedValue;
type            fixedValue;
type            fixedValue;
piston
type            movingWallVelocity;
liner
type            fixedValue;
type            fixedValue;
type            fixedValue;
type            fixedValue;
type            fixedValue;
type            fixedValue;
type            fixedValue;
type            fixedValue;
Old   January 12, 2015, 03:04
I have solved the problem, just because the uniform pressure within the domain is too small, which induces numerical instability.
But now I met another question, calculation inflow has no problems. But when reverse flow happens, negative temperature occurs near the valve-intake BC (which is the only exit).
I have attached the temperature and velocity distribution as below, the left fig is overall view while the right fig is the enlarged view.
[IMG][/IMG] [IMG][/IMG]
Any advice is appreciated....
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
