FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables
Old   December 18, 2014, 05:32
Default FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables
serkan
Sermengi is on a distinguished road
Hello everyone,
I am working on a project about combustion with flamelet model in phorous medium. First i downloaded the flamelet model in the link: https://openfoamwiki.net/index.php/E...n/flameletFoam. It works fine. After this, my adviser suggested the download Flamelet-Model for OpenFOAM-2.3.x which is located in the link: https://bitbucket.org/shor-ty/flameletmodel. I download it also and its tutorial case works very fine. But i want to simulate sandia D flame.
In the tutorials case of the flameletFoam, there are tables for the sandia D flame in .csv format. Is there a way to use these .csv tables in OpenFOAM-2.3.x flamelet model or do i have to create a new tables using the OpenFOAM-2.3.x flamelet model.
I mean, i want to use tables which is located in the tutorial case of the flameletFoam in the OpenFOAM-2.3.x for sandia D flame simulation. I hope, i explained the situation very clearly.
Best regards,
Serkan.
Sermengi is offline   Reply With Quote
Old   December 18, 2014, 09:44
blacksquirrel is on a distinguished road
Hi Serkan,
You downloaded two different codes, which are not compatible.
FlameletFoam (https://openfoamwiki.net/index.php/E...n/flameletFoam, or https://github.com/flameletFoam) is now also available for OF2.3x (including the Sandia D tutorial in RAS and LES)
Hope this helps
Regards
Squirrel
blacksquirrel is offline   Reply With Quote
Old   December 19, 2014, 07:10
serkan
Thanks for your suggestion Squirrel, i will try it.
flamelet table, openfoam
