Boundary conditions for fully-developed turbulent channel flow
Old   December 1, 2014, 03:39
Default Boundary conditions for fully-developed turbulent channel flow
Rasti
rasti is on a distinguished road
Hi Dear Foamers
I am trying to simulate a fully-developed turbulent channel (duct) flow under a constant known pressure drop using standard k-epsilon model.
I want to specify the fixed pressure values at the inlet and the outlet of the channel and other properties (U, k, epsilon an nut) to be periodic, but I found no appropriate BC.
If I use cyclic BC, it is impossible to specify pressure values and if I use pressureInletVelocity there is no chance to use cyclic BC for k, eps and nut.
I read some related posts but no solution found. Would someone help me please?
rasti is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Open Channel Flow - Setting Boundary Conditions Christine Sindelar FLUENT 6 June 6, 2011 05:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
