time varying velocity outlet boundary condition
Old   September 11, 2014, 17:11
Default time varying velocity outlet boundary condition
simin
simin_ds is on a distinguished road
Dear all,
I am simulating flow inside the pipe considering time varying decrease of outlet velocity. for decreasing outlet velocity by time I used the groovy BC boundary condition for velocity as follows:
velocity::::
boundaryField
inlet
type zeroGradient;
outlet
type groovyBC;
variables "U0=0.13;T1=3754;Uout=U0*(1-pow((time()/T1),3));";
valueExpression "(time()<T1) ? vector(Uout,0,0):vector (0,0,0)";
axi_symm-f
type wedge;
axi_symm-r
type wedge;
wall
type fixedValue;
value uniform (0 0 0);
defaultFaces
type empty;
pressure:::::
boundaryField
inlet
type fixedValue;
value uniform 8376;
outlet
type zeroGradient;
axi_symm-f
type wedge;
axi_symm-r
type wedge;
wall
type zeroGradient;
defaultFaces
type empty;
the problem is that after running the case on the terminal page the following message is presented:
--> FOAM Warning :
From function
groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch&
p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
in file groovyBCFvPatchField.C at line 131
No value defined for U on outlet therefore using 30{(0 0 0)}
I think it means that the groovy BC is not defined for outlet condition.
But as I have to reduce the outlet velocity by time could any one help me for finding a proper boundary condition.
Many thanks for the help,
Simin
simin_ds is offline   Reply With Quote
Old   September 12, 2014, 02:42
simin
any idea????
Old   September 12, 2014, 03:09
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
From the error message, "No value defined for U on outlet therefore using 30{(0 0 0)}". So, you haven't defined any value,i.e. initial, at the boundary and it's taking some default value. What you can do is that,
outlet
type groovyBC;
value $internalField; Or uniform (0 0 0) if zero.
ahmmedshakil is offline   Reply With Quote
Old   September 12, 2014, 03:13
simin
Hi Ahmmed,
Many thanks for your help
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
