Problem Creating Splash Interaction model
Old   July 9, 2014, 08:45
Question Problem Creating Splash Interaction model
bilal
brbbhatti is on a distinguished road
Hello Everyone,
I am implementing the new splash submodel in Patchinteractionmodel. I am using some equations from Patchinteractionmodel and some from Thermosurfacefilmmodel.
I have created a new submodel name splash. Then add that in Patchinteractionmodel also. Then in cloud folder inside templates folder in Kinematic cloud files i add new class with name Splash-patchData. This class is called by splash model and its working but i have some error in compiling the library.
In Kinematic cloud.H file it is using a function name "cached rndGen" number. It is using this as
//- Random number generator - used by some injection routines
cachedRandom rndGen_;
and on the same file it is using this with '&' pointer
//- Return reference to the random object
inline cachedRandom& rndGen();
And in thermosurfacefilmmodel it is also using this rndGen. number as
So when i try to write some equations from thermosurfacefilmmodel in kinematic cloud.C file it give error related to some reference of random number rndGen. And also the same case happens when i use this function in splash.C file.
Error is :
I/home/bhb8fe/OpenFOAM/bhb8fe-2.1.0/lib/OpenFOAM/lnInclude -I/home/bhb8fe/OpenFOAM/bhb8fe-2.1.0/lib/meshTools/lnInclude -I/home/bhb8fe/OpenFOAM/bhb8fe-2.1.0/lib/lagrangian_new/distributionModels/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/properties/solidProperties/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/reactionThermo/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/SLGThermo/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/thermophysicalModels/radiationModels/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/turbulenceModels -I/usr/local/openfoam/OpenFOAM-2.1.0/src/transportModels -I/usr/local/openfoam/OpenFOAM-2.1.0/src/regionModels/regionModel/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/regionModels/surfaceFilmModels/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/dynamicFvMesh/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/sampling/lnInclude -IlnInclude -I. -I/usr/local/openfoam/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/usr/local/openfoam/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeBasicKinematicParcelSubmodels.o
In file included from lnInclude/KinematicCloud.H:644:0,
from lnInclude/basicKinematicCloud.H:36,
from parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:26:
lnInclude/KinematicCloud.C: In member function 'void Foam::KinematicCloud<CloudType>::patchData_splash( const parcelType&, const Foam::polyPatch&, const Foam::tetIndices&, Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar, bool&) [with CloudType = Foam::Cloud<Foam::KinematicParcel<Foam::particle> >, Foam::KinematicCloud<CloudType>::parcelType = Foam::KinematicParcel<Foam::particle>, Foam::scalar = double]':
lnInclude/Splash.C:86:3: instantiated from 'bool Foam::Splash<CloudType>::correct(typename CloudType::parcelType&, const Foam::polyPatch&, bool&, Foam::scalar, const Foam::tetIndices&) [with CloudType = Foam::KinematicCloud<Foam::Cloud<Foam::KinematicPa rcel<Foam::particle> > >, typename CloudType::parcelType = Foam::KinematicParcel<Foam::particle>, Foam::scalar = double]'
parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:49:1: instantiated from here
lnInclude/KinematicCloud.C:860:13: warning: unused variable 'patchI' [-Wunused-variable]
lnInclude/KinematicCloud.C:985:18: warning: unused variable 'mDash' [-Wunused-variable]
lnInclude/KinematicCloud.C: In member function 'Foam::vector Foam::KinematicCloud<CloudType>::tangentVector(con st vector&) const [with CloudType = Foam::Cloud<Foam::KinematicParcel<Foam::particle> >, Foam::vector = Foam::Vector<double>]':
lnInclude/KinematicCloud.C:875:44: instantiated from 'void Foam::KinematicCloud<CloudType>::patchData_splash( const parcelType&, const Foam::polyPatch&, const Foam::tetIndices&, Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar, bool&) [with CloudType = Foam::Cloud<Foam::KinematicParcel<Foam::particle> >, Foam::KinematicCloud<CloudType>::parcelType = Foam::KinematicParcel<Foam::particle>, Foam::scalar = double]'
lnInclude/KinematicCloud.C:838:49: error: passing 'const Foam::cachedRandom' as 'this' argument of 'Type Foam::cachedRandom::sample01() [with Type = Foam::Vector<double>]' discards qualifiers [-fpermissive]
make: *** [Make/linux64GccDPOpt/makeBasicKinematicParcelSubmodels.o] Error 1
when i comment out the equation that is using this function then its compiling properly. but i need that function for my model.
I have also attached the kinematic cloud.c file which i try to compile.
Please check that it is giving the error on line 838 where it uses this rndGen_. function.
Anyone have any idea what is wrong or what should i do.
Best Regards,
Bilal
brbbhatti is offline   Reply With Quote
Old   July 11, 2014, 05:42
bilal
Hello ,
no one have any idea what is wrong??
Old   July 11, 2014, 06:43
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
in fact the error is quite self explanatory rndGen_ is a constant, while sample01 method modifies the instance of the class. I wasn't able to figure out why it is constant for the source you've provided.
alexeym is offline   Reply With Quote
Old   July 3, 2015, 04:31
Default Any fix for this issue??
Ananda Kannan
ansubru is on a distinguished road
Hi!!
I have encountered the same problem while trying to initialize a Gaussian random number within the class Wallspringsliderdashpot, used in Lagrangian particle tracking... .../src/lagrangian..
Here is the screen stack trace of the error reported while compiling the code -
lnInclude/WallSpringSliderDashpotvib.C:118:5: error: passing ‘const Foam::Random’ as ‘this’ argument of ‘Foam::scalar Foam::Random::GaussNormal()’ discards qualifiers [-fpermissive]
lnInclude/WallSpringSliderDashpotvib.C:122:5: error: passing ‘const Foam::Random’ as ‘this’ argument of ‘Foam::scalar Foam::Random::scalar01()’ discards qualifiers [-fpermissive]
lnInclude/WallSpringSliderDashpotvib.C:392:9:   instantiated from ‘void Foam::WallSpringSliderDashpotvib<CloudType>::evaluateWall(typename CloudType::parcelType&, const Foam::List<Foam::Vector<double> >&, const Foam::List<Foam::WallSiteData<Foam::Vector<double> > >&, const Foam::List<Foam::Vector<double> >&, const Foam::List<Foam::WallSiteData<Foam::Vector<double> > >&) const [with CloudType = Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >, typename CloudType::parcelType = Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> >]’
parcels/derived/basicKinematicCollidingParcel/makeBasicKinematicCollidingParcelSubmodels.C:53:1:   instantiated from here
Any tips on how to resolve this issue. My initial thoughts are that I should maybe try to declare the random number generator differently..
Btw, here is my current code modification to the class wallspringsliderdashpot -
template<class CloudType>
void Foam::WallSpringSliderDashpot<CloudType>::evaluateWall
    typename CloudType::parcelType& p,
    const point& site,
    const WallSiteData<vector>& data,
    scalar pREff,
    scalar kN,
    bool cohesion
) const
alphaR = sigmar*GaussGen.GaussNormal();  // Gaussian normal distributed polar angle
    // Sample uniformly between 0 and 360 [0 - 2pi]//
    phieR = 360.0*RanGen.scalar01();  // Gaussian normal distributed azimuthal angle
    scalar normalYcomp= rHat_PW.y();
    scalar normalZcomp= rHat_PW.z();
    vector t_a = vector(0.0, -normalYcomp, normalZcomp);
Any ideas guys??
ansubru is offline   Reply With Quote
kinematic cloud, rndgen, splash
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
problem in glass radiation model (DO model) wunan805 FLUENT 0 October 10, 2012 06:06
Problem in Buoyancy Model? dhrubo CFX 3 June 5, 2010 06:32
A model is used to model particle interaction with the geometry dungsidietquy FLUENT 0 November 4, 2009 17:05
