simulate a barrel with fluid inside and air above the fluid
Old   June 21, 2014, 15:23
Default simulate a barrel with fluid inside and air above the fluid
Richard Vega
richard_vega is on a distinguished road
I am new to OpenFOAM and I have a simulation that I would like to perform. I believe the best solver for my purpose would be interFOAM, but I will let you all be the judge. The problem is relatively simple: I want to simulate a barrel with fluid inside, and air above the fluid. In the simulation I would like the barrel to tip over and for the fluid to slosh around inside. My main question after reading through the dam breaking example is how to account for the accelerating boundary conditions (the fact that the barrel is what is moving and the fluid is reacting to this movement). I have not seen any examples like this, but I am sure it can be done. Any advice?
richard_vega is offline   Reply With Quote
Old   June 21, 2014, 19:57
Wouter van der Meer
wouter is on a distinguished road
Hello richard_vega,
nice to be so confident. Using interFoam should be oke. I have no idea if this works but I would suggest that you change the gravity vector in time with the help of groovyBC. Presenting the results is I think the most difficult part.
good luck and hope this helps,
Wouter
wouter is offline   Reply With Quote
Old   October 7, 2019, 09:20
Mi95 is on a distinguished road
hey guys,
i dont know if my question is trivial or not, but im having a very similiar case, where i want to simulate a fluid column under a air layer on top.
I considered as you already mentioned the interFoam solver.
But the description of it says:
InterFoam Solver for 2 incompressible, isothermal immiscible fluids using a VOF
my question regarding that would be why it is even possible to simulate the breaking of a dam with interFoam, as the air in the atmosphere is compressible?
do you have any idea?
Mi95 is offline   Reply With Quote
interfoam, moving bc, openfoam
How to simulate a simple fan inside a room ? rafiktharwat CFX 10 September 23, 2014 03:51
analyzing the temperature of fliud (air) flow inside an underground duct. arshbunny CFX 9 April 3, 2014 09:52
Air speed estimate inside a box with one barrier cognitor Main CFD Forum 1 May 14, 2013 08:43
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 17:30
can we Simulate air bubble inside hot liquid Mohan FLUENT 0 December 15, 2005 15:22
