Pressure farfield Boundary condition for OpenFoam |
May 8, 2014, 09:37 |
Pressure farfield Boundary condition for compressible solvers of OpenFoam
Rep Power: 15 |
I am trying to resolve the steady compressible flow around an airfoil. I need a B.C similar to Pressure farfield BC in FLUENT.
does this BC exist in OpenFoam ? The definition of this BC in the fluent manual is: Pressure far-field conditions are used to model a free-stream condition at infinity, with free-stream Mach number and static conditions being specified. The pressure far-field boundary condition is often called a characteristic boundary condition, since it uses characteristic information (Riemann invariants) to determine the flow variables at the boundaries. for more information about the Calculation Procedure at Pressure Far-Field Boundaries please see the below link http://aerojet.engr.ucdavis.edu/flue...ug/node242.htm Sincerely Last edited by mechy; May 9, 2014 at 04:26. |
May 14, 2014, 00:44 |
Rep Power: 15 |
this B.C is used for compressible flow.
December 30, 2018, 09:21 |
Bidesh Sengupta
Rep Power: 8 |
Hi!!
I am having doubt, if you kindly help me to clarify those, it will be very useful. I have spherical mesh domain and at the center I have a plate and I wish to compute aerodynamic coefficients at different conditions. I have to use compressible flow. I am using freestram as BC for p and U, but not sure as I am getting diverged. Also I see negative k and epsilon (which is wrong). How can I calculate k and epsilon for farfield. Thank you very much. And happy new year. Bye |
Pressure boundary condition | C-H Kuo | Main CFD Forum | 18 | September 16, 2016 03:19 |
how to replace a shock tube high pressure port by a boundary condition? | immortality | OpenFOAM Pre-Processing | 0 | May 2, 2013 13:43 |
pressure wall boundary condition in CFX | murx | CFX | 4 | October 9, 2012 06:50 |
high pressure boundary condition | fragzilla | CFX | 5 | September 14, 2012 02:40 |
